Question about Car Audio & Video
Need a wiring diagram
I cant find the hot or ground on the stereo connection for my 99 gmc sierra
    Sergeant:
  • 187 Answers
HI,
1999 GMC Sierra Truck Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
please rate my suggestion....
Posted on May 22, 2009
    Problem Solver:
  • 15 Answers
You should have bought a wiring adapter from walmart $7.99 but black is usualy the ground from there they sell voltage testers at any car part store any wire with power when the key isnt on is the memory wire, wire with power only when key is on is the acc hope this helps
Color coded wiring diagram 1995 gmc sierra electric windows
Google the
wiring diagram 1995 gmc sierra electric windows I found several systems offering what you require.
But what is the problem, 99% of the time in that year the window regulator was at fault, it was made from a stapped steel housing verses an cast unit. We check the left switch for power, disconnect the two wire connector at the motor, and see if the motor has power to one side or the other in the connector. If the switch has power to it, and the motor has power to it as you press the button, the motor is at fault.
Good luck.
Mar 16, 2015 | GMC Cars & Trucks
Want to install an amp to my gmc sierra sle crew cab
Locate an area for the amp to be mounted.
Amps get hot so, there needs to be plenty
of air space around the amp.
1. Mount the amp
2.run the main power wire, with an in-line fuse,
to the "+" positive side of the battery.
3. Ground the amp to the metal part of the chassis
4. Run the remote wire(usually a blue wire) to the stereo
so the amp powers up with the stereo
5. Run the stereos, speaker wires , from the stereo to the input side of amp
6. The output side of the amp to the speakers that are to be driven
if everything works then you are finished! Congrats!
Jan 18, 2014 | Cars & Trucks
Door speaker wiring diagram for 2002 sierra
2002 GMC Sierra C1500 Car Radio Wire Color Codes
Car Stereo Amplifier Location: Under the center console.
Dec 20, 2012 | 2002 GMC Sierra 1500
Wireing diagram for a 03 gmc sierra pickup for a pioneer DEH-1200MP stereo please
Hello my name is Israel and I will help you. The following information will help you out. Please rate. Good Luck.
Feb 28, 2011 | Pioneer Car Audio & Video
I want to install an aftermarket stereo in my 06 GMC Sierra. Do you have the wiring diagram for the factory stereo harness?
go to walmart or bestbuy and get the wiring adapter so you dont have to cut any wires. they are color coded
Oct 22, 2009 | 2006 GMC Sierra
Factory radio wiring color codes
Here ya go. enjoy!
May 14, 2009 | 2002 GMC Sierra 1500
Installing an aftermarket stereo, spliced the wires and have everything connected including the remote wire to the factory amp wire but still no sound.
There is no remote wire on these newer trucks....03 and up....u have to buy the harness....although i didnt....i have an 03 gmc sierra and just pulled the schematic and matched the wires. And there is no programming to do on an aftermarket stereo.....I work for GMC and we cant program aftermarket stereos......if u buy the right harness ...and its over $100 then everything should work just fine.....and this does not disarm ur alarm system either....mine still works fine....hope this helps
May 08, 2009 | 2003 GMC Sierra
Stereo wiring diagram
Apr 15, 2009 | 1999 GMC Sierra
I need the color codes for a 1988 GMC Sierra stereo.
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Rear Doors
Mar 03, 2009 | 1998 GMC Sierra
Car Audio & Video Logo
305 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
