Question about Samsung 55" Series 6 LED HDTV - UN55F6300
Screen flashing green - Samsung 55" Series 6 LED HDTV - UN55F6300
Flashing Green Screen and lag
A green screen display to plasma displays is a bad symptom. It might be a panel defect. You just get into the site named 'Electro-help' by search, and get the site begins with 'electronicshelponline.blogspot' as its URL. There is screen shots to different faulty screens to plasma displays, which I can't include all of them this by this window. Check them and make confirm.
May 24, 2013 | Televison & Video
Screen has a blue green look
Your question lacks details. is the green screen on flash based videos such as Youtube? If yes, right-click on it > Settings > Uncheck 'enable hardware acceleration'.
Here's a step-by-step tutorial how to do it:
http://darktips.com/fix-flash-player-green-screen-video/
Nov 20, 2012 | Panasonic PT-AX100U-EC DLP Projector
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
Screen flashes green a couple times then shuts off
you need a new green CRT. The lines were retrace lines which are the first sign of a tube developing a short eventually the green will short completely and cause the set to shutdown.
Feb 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Samsung 55" Series 6 LED HDTV - UN55F6300 Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
