Question about Philips PD700 7 in. Portable DVD Player
Philips PD700/37 does note see my disc nor does it spin
Does not spin or load
Philips PD7012/37 will not spin disc
Disc loading mechanism fault. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Pull up older posts.
Jan 26, 2017 | Philips Televison & Video
DVD ejects itself shortly after inserting
If you have tried cleaning the laser lens and the unit does spin,You have a defective laser assy,this is common with these players.If unit does not spin,try spinning it when you insert a disc by hand as this may start the unit spinning,if starts spinning then unit has a bad spin motor.
Apr 13, 2010 | Philips Televison & Video
My player when loading dvd loads for couple of secs and cuts off
Does the disc spin?
If not you have my problem spindle motor suspected faulty if the disc spins then its not being read, faulty lazer assy Try cleaning the lazer using dry brush disc philips do a good one and also clean the disc you are trying to play if it still doesnt work its a fault
Sep 02, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
AZ5737 philips DVD says NO DISC after inserting the disc.;please help
Clean the lens with a soft cotton cloth but be careful not to touch it with bare hands. Make sure the lens is not soiled with dust.
Note: if it says 'NO DISC" immediately after closing the tray, check capstan motor if spins smoothly. It is the one spinning the disc. Open the unit's casing to have a view of the disc when playing. If it doesn't spin, replace capstan motor.
Check also for abnormal heating of any IC on the module. Replace if there's any.
Aug 30, 2009 | Philips DVP3962 DVD Player
After loading a disc it says "no disc"
Aug 25, 2009 | Durabrand DUR7 Portable DVD Player
DVD player plays VCD/SVCD but not DVD
there is a problem with the disc motor, replace it
Apr 08, 2009 | Philips DVP642 DVD Player
The spin motor doesn't turn spin the disc
yes you can replace your lens also your lens is not working so you have to change
May 18, 2017 | Philips DVP5960/37
Philips dvd783c wont spin.
It sounds like one of the hindge/wheels are off set. Most of the time that can also cause the lazer lense not to come up all the way in order to properly read the disc. When you keep the door open and press start does it allow the lazer lense to come up all the way? That is the small circle glass peice you will see when you look in--some you can see it some you cant.
Let me know.
Thanks.
Mar 31, 2008 | Philips DVD783CH Multi-disc DVD Player
Disc load error
DVDs spin at constant linear velocity. This means that the disc can be spinning slowly or relatively fast, depending on where the laser is positioned on the disc and what function is being used at the time....accordianman
Dec 18, 2007 | Philips MX3600 System
Philips PD700 7 in. Portable DVD Player Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
