Question about Becker Underwood Inc Neutralize Spray Tank Systems Cleaner
Daughter has broken a bottle of hilex bleach on our driveway in the winter
How can I neutralize a bottle hilex bleach that was dropped in our driveway after returning from the store in winter conditions?
  • 653 Answers
Hilex brand bleach is just plain chlorine bleach, also known as Calcium Hypochlorite. It will oxidize quickly with exposure to the elements, or if the odor bothers just hose it down in the direction of the street. Don't worry about environmental impact since it will be too degraded and diluted to be any harm.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CC4QFjAA&url=http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FCalcium_hypochlorite&ei=0jTHUqCdIaG2sASGyYHgDA&usg=AFQjCNHWf4VYNkuEnUuFEa_MRSfw8ZxRug&bvm=bv.58187178,d.cWc
Posted on Jan 03, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How do i winterize a primo water dispenser #601118
get a gallon of RV antifreeze (it is not toxic)
put it in cabinet where the water bottle goes, connect the intake hose to the antifreeze bottle.. Then use the dispenser as normal till the antifreeze comes out both dispensors. When you go use it next time take the antifreeze bottle out, put in a regular water bottle and run the water till the antifreeze is gone.
Jan 16, 2016 | Cars & Trucks
Backed out of driveway, van would not come out of reverse. pushed to side of road. dash light stays on "R" and van will not start at all
Sounds like a possible shift linkage problem. Follow linkage back from your transmission, look for bent levers, broken or bound up pivoting connections. The neutral start switch prevents starting of engine when transmission is not in neutral or park.
Aug 02, 2015 | 2004 Toyota Sienna
HOw to attach soap bottle to earthwise 1850 pressure washer
It should have a tube on it put it in your bleach bottle and use the black tip for dispense 1/2 bleach/1/2 water
Aug 08, 2013 | Earthwise 1850 PSI Electric Pressure...
My '04 Pacifica won't start. I occasionally hear a loud "click" which is , I assume is the starter solenoid trying to kick in. The Click seems to be at the left front, (where belt and...
neutral run relay ? no such thing . park neutral safety switch on the transmission , have B+ voltage on one side if the switch is in park or neutral B+ voltage will pass through to the PCM - engine computer . If the PCM see's this B+ input it will energize the starter notor relay located in the under hood fuse / relay box . This will send B+ voltage to the S terminal on the starter solenoid . If you hear a click under the hood , an it is the starter solenoid . You could have a bad starter , or a voltage drop in the cables or battery connections . Doing a voltage drop test on the starting circuit is the thing to do first . Starter Voltage Drop You can find the starter 07 Chrysler Pacifica AWD 4 0 starter replacement yours is in the same place
Mar 01, 2017 | 2004 Chrysler Pacifica
I have a model awn412SP top loading washer we bought last year - a plastic bottle of bleach that was on a shelf above ate through and dripped into our washing machine stainless steel tub - that also ate...
Clorine is very strong caustic . It can and will eat tru steel. Run baking soda through serval wash cycles followed by vinegar and rinse again with baking soda. This should remove the bleach or at least neutralize the caustic solution
Mar 08, 2010 | Washing Machines
Becker Underwood Inc Neutralize Spray Tank Systems Cleaner Logo
90 people viewed this question
Top Data Becker Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Data Becker Vehicle Part and Accessory Expert? Answer questions, earn points and help others
