Question about Seagate Barracuda 7200.7 200 GB Hard Drive
External Segate 200 GB SATA Hardisk (USB 2.0 connection to PC)
I diagnosed my external hardisk with a scandisk of windows. While it was on going - my nephew accidentally unplug the power supply of the external i tried turning it back on,,,then it cannot be read by the pc anymore though during the start-up the Hardisk can be detected but cannot be read and causes the windows start-up to hang. Even if I tried  connecting the hardisk directly to the SATA connection of the motherboard...but still it cannot be read though it was detected - the PC will hang. I tried everything even with the use of MAC. I even tried some software that will boot directly trough DVD-ROM and try to recover it. But still though it can be seen in a window style screen - but when I try to click it (drive letter) - the system hangs. But I think the hardisk is still running coz I can still feel the heat in the hardisk when I touch it. Please help ...thanks a lot....
  • atom911 Oct 19, 2007
    you better pray man....
  • atom911 Oct 22, 2007
    ....but the problem is that when ever i connect it either directly thru sata connection or by the USB external connection - it takes more than 30 minutes to appear in the drive letter  and most often when I click it - it hangs.....thanks  for your help guys...I really appreciate it/
  • 382 Answers
I appears the volume may have been corrupted. YOu should run data recovery on the drive if you need any of the content. If not reformatting the drive, should restore it. If the contents are not important, or you have it backed up, go ahead and connect it to the MACINTOSH and format it for MS-DOS.
Unless it is physically damaged ( clicking, beeping, knocking ) it shoud be usable.
Hope this helps.
Posted on Oct 20, 2007
Need to reformatt
Just connect ur external hardisk with your pc through usb cable, the right click on the hardisk and click on format
Sep 11, 2011 | Western Digital WD Passport 250GB Portable...
Sata hardisk is not working "usb not recogenised"
Connect hardisk directly to computer without usb
go to start > run > cmd
type chkdsk /p enter
it will fix your problem
remove hardisk via safe remove
and connect via usb cable
Jul 29, 2011 | Conrad WD HDD 250GB SATA 35" WD2500AAJS...
My hard disk have problem if i open may pc in go to 2 my os he said disk boot failure what can i do pls help me pls.
Kindly Try this:
1. Restart your PC
2. Repeatedly Press F9 (Window must appear with list of Drives on it)
3. Choose the drive where your OS is installed.
Hope that this help.
Else give me feedback for me to get back to you.
Mar 16, 2011 | Computers & Internet
My laptop Model Compaq 5204NR I want to extend my hardisk. Is it possible to use External Hardisk for this model laptop. If it means how much can i use 1TB hardisk or which is suitable for this laptop....
Yes you can use an external HDD to extend your current HDD. If by extend you mean use the external HDD for storage and such.
However if you wanted to literally extend your current HDD by creating a single partition for both HDDs then it could be extremely problematic because the external HDD will be connected with an USB cable. If you were to accidentally unplug the usb cable then your whole system would crash.
Feb 28, 2011 | HP Compaq Presario V5204nr Notebook
Boot device not found Please instal l an operating sistem on your hard disk. Hard Disk - (3FO) F2 Sistem Diagnostics Foe more information, please visit:
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
Feb 01, 2011 | HP Pavilion dv6000z Notebook
I have a Assembled Computer with Processor Intel Dual Core (R) @ 270 GHz, 3 GB of RAM equipped with Microsoft Windows XP Professional Edition version 2005 service Pack 3 with Wi-Fi Netgear 108 Mbps Lan...
yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
Aug 22, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Hardisk cleaned why?
this may be a hdd physical failure, best to check this would be to connect disk to another computer for a minute and run full HDTACH tests, if it's not damaged, then boot record is damaged, and Partition magic or similar program is needed to delete partition and re-create it
Sep 19, 2009 | Western Digital 250GB MyBook External USB...
My segate hardisk 160 GBhas been dead
why don't you try, they have listing of all SEGATE service centers in india.
Jan 19, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
When i connect my seagate via usb nothing comes up on my pc, the light comes on on the external h/d but nothing pops up on the pc? help please i need precious photos on it. thanks
have you try connect your pen drive to the same usb port, is it working?
If Pendrive is working but not the Seagate hardisk. Most propably is your USB power is not enough to support the External Seagate hard disk, you need to supply more power to the Seagate hard disk by using USB Y cable(1 end connect to Seagate hardisk where the other end got 2 USB connector to connect to your PC).
Jul 30, 2008 | Computers & Internet
Seagate Barracuda 7200.7 200 GB Hard Drive Logo
176 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
