Question about Mattel Hot Wheels Remote Control Nitro Speeders Team Mustang Car
Hot wheel nitro speeder won't charge
It won't take a charge green light won't come on....I tried charging but no luck at all
Quingo plus mobility scooter won't move battery charged green light on not flashing tried manual brake still won't move
-Even the green light show power or charged but may be no enough power to move or spin the wheel.
Test it to find out.
Good Luck
Mai
Jan 10, 2018 | Health & Beauty
Craftsman Cordless Screwdriver Model 315 111202 won't charge
I took mine apart because it would not charge and the one terminal was very corroded but the battery is soldered to the terminals and no markings on the 2 batteries. Good Luck
Feb 25, 2012 | Home Security
My tomtom one wont turn on.
there is a reset on that which you will need something small-paper clip works really well-to push in. Pop your memory card out and push in, then hot reset-good luck!
Nov 17, 2011 | Tomtom One GPS
Hello My wife has a go go ultra scooter and all the sudden it seems like the brake is on all the time while driving forward and killing the battery.The batteries check at 12.7 full charge but die within...
Hey,
well there is another way of checking the battery's and thats by load testing them.
1)Fully charge the battery's
2) load test both batterys make sure they are reading close to the same
If both battery's check out good than ,The next step would be to check that brake assembly.
1) Put the scooter on blocks so when you drive it doest runaway
2)Take the rear wheel off that the brake side is on
3) Put the scooter in drive with some tape or rubber band to hold it in drive
4) Make sure theres nothing in the way if the scooter should fall
5)check your break if it abnormally hot
If it is in fact abnormally hot ,the you have a break problem.
Hope i was able to help,good luck..
Jan 17, 2011 | Pride Mobility Products Go Go Ultra X 3...
Battery new cahrging good green light flashes
Hi. How many times does the light flash betwwen pauses? this is a fault code. Check free-wheel lever. Check motor and battery leads and connectors.
Check the resistance through the motor with a multi meter.
Good luck. Neil.
May 09, 2010 | Pride Sonic 3 Wheel Portable Scooter
Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Batterys will not hold charge
Hi kevinsharpe8;
Right off the top of my head I would suspect the charging circuit. The way to check this is to measure the voltage at the batteries while they are on charge. The voltage reading when they are supposed to be charging should be higher that what you would read at the batteries when they are not charging.
These charging circuits are not complicated and any electrician type should be able to trouble shoot the circuit and find the problem
Hope this helps Good Luck Loringh PS Please leave a rating if appropriate thanks
Nov 20, 2008 | Saws
Mattel Hot Wheels Remote Control Nitro Speeders Team Mustang Car Logo
335 people viewed this question
Top Mattel Televison & Video Experts
Steve Mason
 Mikey
Mikey
Are you a Mattel Televison and Video Expert? Answer questions, earn points and help others
