Question about Troy-Bilt Garden
The thrower isnot really throwing the light snow any distance.
The thrower is about 4yrs old.
  • 114 Answers
Worn blades
Posted on Nov 20, 2014
  • 28 Answers
SOURCE: How do I adjust the belt on my Ariens 11528 snow
by the handle under the handel little ajustable rod
Posted on Feb 22, 2009
  • 715 Answers
SOURCE: !332 Snow Thrower will not Start - At full choke
change gas filter and spark plug
Posted on Oct 07, 2009
  • 3911 Answers
SOURCE: Is there a GENERIC Snow thrower for John Deere 110?
Two Stage - Snowblower - Snow thrower - Bercomac All of the Bercomac attachments are interchangeable on the same quick hitch mounting. Bolts on in minutes. What a great idea for people who have more than one tractor or buy a new one. No more having to go and buy all new attachments for the new small tractor, just buy a different model hitch kit if it doesn't use the same one. The resale value is preserved when you can sell your attachments to be used on another size or model lawn and garden tractor.
camcorder-pic.jpg Snowblower video clip
Snowblower-Snowthower Q&A's
If you are ready to buy or want more details give us a call: 1-800-618-8738 or e-mail jim@jimsrepairjimstractors.com
Posted on Oct 15, 2009
wireguy212
  • 1627 Answers
SOURCE: Ever hear of a PTO running in reverse? I have my
Is your blower running off of a belt or a pto shaft?If it is running off of a belt then you likely have a twist in the belt that shouldn't be there ,have a look at it to see if it crosses it's self somewhere.If it has a shaft then the drop box needs to come off and the gear arrangement checked out.
Posted on Jan 08, 2010
huffman49
  • 235 Answers
SOURCE: Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Posted on Apr 14, 2010
Will not blow wet snow. Clogged up all the time
Since you did not clearly state what type of instrument or mechanical equipment you are using to blow wet snow with, I will assume you are referring to snowblowers or snow-throwers.
They are not designed to be used on wet snow, since the snow is too heavy- however they are designed to throw light powdery snow
http://www.accuweather.com/en/weather-glossary/wet-vs-powdery-snow-2/5060689
https://www.quora.com/What-is-the-difference-between-dry-snow-and-wet-snow
Feb 13, 2017 | Garden
ISnowblower is throwing snow, but also putting snow up on the machine ananda on me. When I finished one row the machine is covered with snow!
There are many factors that can cause this to occur. ONE IS THE WIND, LIGHT SNOW WILL BLOW BACK OR SNEAK THROUGH HE CRACKS OF THE EXIT. if THE SNOW ON THE OTHER HAND IS WET THEN THE EXIT CHUTE WILL ALLOW THE SNOW TO DROP ON THE MACHINE. ONE WAY TO FIX THIS REQUIRES THE ADDITION OF RUBBER STRAPS, YOU WILL NEED TO DRILL HOLES IN THE IMPELLERS and attach the rubber, (this can be cut from an old tire or a floor mat or other rubber that is around 1/4" thick or more. Make the parts the width of the blades and around 2-3 " from tip to base. This will stop the snow from collecting on the walls of the blower and throw the snow farther from the blower.
sorry about the uppercase, did not know I had hit the caps lock, not a touch type person.
Neal
Feb 26, 2015 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Huskee snow thrower spout clogs
Before use spray chute/housing with Pam or WD-40
Also push unit faster to move snow through easier.
Feb 24, 2015 | Huskee 21 in. Single-Stage Snow Thrower
Snow blower will not throw snow far
I take it that you have a 2-stage snow blower, that is is has the auger blades and then the 2-stage impeller. The impeller blade is damaged <<OR>> the motor is to small to through the snow far. If you have a 5-horse engine and throwing heavy snow, the snow may not go as far as the light fluffy stuff.
A single stage snow thrower is not designed to throw snow far, just move it over a bit.
Oct 10, 2014 | Garden
Snow thrower not starting
Two ways to find out:
1.
2.elctric
start with elctric, take the plug cable out and see if have
https://www.youtube.com/watch?v=mUOmsGiirTU
if you have spark go to fuel :
change the old fuel to a fresh one.
https://www.youtube.com/watch?v=RfzzTilqwo0
Dec 13, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
What is a snow blower?
A snow blower gets rid of snow. There are one stage blowers (called snow throwers) that just throw the snow away. There are also two stage blowers that have one stage where the snow is put into the machine and then a second stage where the snow is blown away.
Jan 16, 2013 | Garden
Wheels losing power on Ariens 5520 snowthrower
i would open the bottom access panel and tighten the tension on the drive belt. i had a simailar problem with my 5520, it wasn't my wheel drive, but my thrower. it would throw snow intally, but stop as soon as it got in deep snow. when i opened the panel, i noticed the the tension on the belt was really loose. so i pushed the fly wheel close to the belt and tightened the fly wheel..and VIOLA as good as new. hope that helps...
Feb 10, 2010 | Air Tools & Compressors
Garden Logo
83 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
