Question about Dell UltraSharp 1907FP 19" LCD Monitor
I have a Dell monitor model 1704FPT,, seems like the power button has come loose inside.. Can I get inside to repair it .. Thank you
    Sergeant:
    Champion:
  • 225 Answers
You can turn counter-clockwise the screwz at the back cover of your monitor to open it & check if the power button is loose or defective, even notice if some internal part/s are cold soldered / defective. However, if it's still under Warranty, I recommend to bring the unit to an authorized service center for a Free service check-up & replacement part/s. best regards
Posted on May 25, 2009
I have a Dell ultraSharp 1704FPT 17 in.Flat panel LCD monitor and the power button keeps on blinking green but nothing shows on the display.i tried my cpu on different monitors and it worked well but my...
I think you answered your own question--the computer works well with other monitors, but not this one.
I would suspect that this one is bad.
You might try to do this: Start the computer in safe mode and see if your monitor is reacting to video settings that are beyond it's capability (although if this is the case it should tell you it's out of range).
If it works in safe mode, try resetting the resolution to see if it will work with the new monitor (I seriously doubt that this is the problem).
Oct 07, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704FPT won't come on at all. Only the sound
  • Check connection integrity at both ends of the video cable
  • Ensure the monitor and computer are plugged in to a working electrical outlet
  • Ensure power button depressed fully
  • Press the input select button the front of the monitor and ensure the correct input source is selected
  • Increase brightness & contrast controls
  • Perform monitor self-test feature check
  • Check for bent or broken pins
  • Re-boot your computer and monitor.
Jan 17, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704FPT just went dead, will not turn on not even yellow light on power button - just seems to have died. Is there a way to reset? or is it time for a new one?
First you need to troubleshoot a little. You should first try another power cable for the monitor, if that doesn't help, you might be able to open up the monitor case and check wether the button is broken. If the button is broken, you're going to have to improvise a new one, since new buttons aren't really being sold. If that isn't the case, or if you can't open up the monitor, take it to computer shop, these things are easier to fix if you can look at it. I hope this helps, Yannick.
Jun 06, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
No lcd light
Hi...there,
It's seems your backlight inverter/ built-in power supply are busted. Need to replaced a new one or repaired it...
Nov 29, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell UltraSharp 1704FPT 17 in
Remove the stand, look along the bottom edge - you will see two small slots, one either side. Poke something in the slots and wiggle slighly, the corner will come apart - then just pull until all the clips undo.
Sep 07, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Pink tint on Dell 1704FPT Flatpanel LCD
The monitor is broken. The circuits that generate green in the RGB setup are not working. If its under warranty, replace it.
Apr 23, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704FPT Display Problem
It is your inverter/power supply board. Costs around $62.00 with shipping. Not a hard replacement if you have electronic maintenance experience.
Jan 22, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704fpt Screen turns white
ok,your monitor has a defective vertical ic.when vertical ic is defective you can see the horizontal line.
Oct 18, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell UltraSharp 1907FP 19" LCD Monitor Logo
447 people viewed this question
Alun Cox
