Question about Nespresso Citiz D110
Can't remove water tank krups nespresso citiz
    New Friend:
  • 154 Answers
Open led and pul tank out if not try doing descale it may have got stuck from solts
Posted on Dec 12, 2016
5 Suggested Answers
SOURCE: My Nespresso citiz lungo button will only give
Ok, what you have done is programmed your machine. If you hold down the button for 3 secs you get 3 secs of coffee, so turn on your machine wait for it to warm up then without using a capsule press and hold the button until you get 110mls for a lungo and this will be stored in the memory. If this doesn't work there is a on/off switch on the right handside turn it on with your finger down on the lungo button for 5 secs and then release the button and this will take it back to factory settings.
Posted on Jan 25, 2011
  • 3513 Answers
SOURCE: I bought a Nespresso Citiz
Most probably the leak is for the seal between the metal heating coils, and the plastic switch that selects steam or coffee. Possibly caused by no cleaning the injector hole with the tool provided with machine (which causes a lot of back pressure).However since the machine is new you cantact customer service for free checkup of the problem,or you can claim to replace the faulty machine .
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Posted on Aug 01, 2011
  • 6 Answers
SOURCE: My Nespresso Magimix Citiz does
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Posted on Dec 26, 2011
  • 3799 Answers
SOURCE: where can I get spare parts for the Krups Nespresso Citiz XN. specifically the Drip tray and the base it sits on
Why don't you try "Krups" ? I would think this would be the best place to start. Ask them if they stock the spares and if not where they are available.
Posted on Feb 24, 2012
CitiZ swap outside casing
I've stripped the casing from this model and it isn't difficult, though you do have to be careful. You should check out the Service Manual for the machine to first to decide if you're up to the job. The service manual is readily available online, just Google, 'Nespresso Citiz Service Manual' and you should get it in PDF format. The manual explains the process for dismantling and re-assempling. It also conatins wiring diagrams for all versions. It looks like the casing is the same, regardless of country. When I stripped mine, I didn't have the specialist Nespresso tools for the job, but carefully inprovised using small pliers instead of the special oval screw driver. BEWARE...any remaining warranty will be invalid if you carry out any work on the units!
Jul 23, 2013 | Nespresso Citiz C110
Nespresso not making any noise, water not coming out
return it to place of purchase as defective w/ receipt
Oct 06, 2017 | Krups Nespresso Citiz And Milk
Where can I get spare parts for the Krups Nespresso Citiz XN. specifically the Drip tray and the base it sits on
Feb 24, 2012 | Nespresso Coffee Makers & Espresso...
No water, flickering lights
might have a lose wire inside the unit, do the wiggle test, take the unit apart and wiggle the wires they should all be attached firmly if you find one that is lose that's the one and he needs to be tightened up or replaced with a new terminal.. jay the pool pump motor repair guy in longwood Florida
Feb 03, 2012 | Nespresso Citiz C110
Hi got a krups citiz nespresso machine it keeps on falshing and don't heat up
many times if you call the company they are all to happy to help you out. Or email them of course. I just phoned the company that I bought speakers from and said my cat ate the wires and they are giving me a new set for free!
May 17, 2011 | Krups Coffee Makers & Espresso Machines
We have a Nespresso Citiz C110 which today decided to start having problems. It starts its cycle perfectly but as it is filling the cup the water goes cold and after a few seconds switches the pump off...
Sounds like it needs to be descaled. If this has not been done for a very long time, the scale will have affected the thermoblock and I may not return to full function. I only use Nespresso descale kit (not vinegar).
Jun 21, 2010 | Nespresso Citiz C110
Nespresso Citiz D110 Logo
696 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
