Question about Vizio VF550M 55 in. LCD HDTV
Tv not responding to remote vizio vf55om - Vizio VF550M 55 in. LCD HDTV
SOURCE: code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Posted on Dec 23, 2008
  • 139 Answers
SOURCE: Vizio VW32L HDTV10A stopped responding with Vizio
Change the batteries in your remote. If your cat was laying on a button it could have drained them.
Here's tip - you can use your camera on your cell phone to see the IR signal coming out of your remote. Point the remote at your cam and press "On" or any button. You should see a bright flash with every key stroke.
Posted on Mar 06, 2009
  • 4 Answers
Unfortunately, those remotes only take a 3 digit code. I bought 2 new remotes, which do take 4 digit codes, but the code(s) for the Vizio do not work (or partially). I found that the 4 digit codes for the Goldstar and LG work better than those provided for the Vizio, but still not as good as the original Vizio remote.
Posted on Apr 01, 2009
SD Tech
  • 14553 Answers
SOURCE: vizio vl370m remote control
If remotes have been ruled out the only way to test the remote infrared receiver is with the set apart/ and a schematic measure voltage at the receiver when the remote is used---most of the time since the part is rather small this is just replaced to see if it is or is not the problem; some receivers will fail where if the remote is held very close they work--always the receiver in that case.
Posted on Apr 12, 2012
SOURCE: my Vizio VX32LHDTV10A 32 in. HDTV LCD TV will not turn on. It shows that it has power(VIZIO emblem on front is lit) but does not respond to remote or power button on side
if you have a picture or video of what it looks like, that would be great
Posted on Dec 09, 2012
Just replaced the power supply Backlight inverter to Vizio Model E470VL TV. It works fine now but I can't get the remote control or a Universal remote to work. Do I need to purchase a special remote?
If the remotes have good batteries and are both working, and the set still does not respond, you might try to reset the sets electronics. If that does not do the trick then the board responsible for responding to the remote signals generated has an issue.
Feb 23, 2017 | Vizio Televison & Video
Vizio tv remote not responding
possibly bad batteries in the transmitter. could also be a blocked IR receiver at the TV(do you have something in front of the IR receiver in the TV?) last resort could be either IR receiver PCB or the MAIN PCB.
Mar 03, 2015 | Vizio VW42LF 42 in. LCD HDTV
My vizio remote works but the tv doesn't respond. I replaced the remote anyway but it still doe not work. resetting tv doen't work what is next?
It is possible the remotes are either bad or not compatible to the tv. Recheck the remote type and the batteries to see it that helps.
Feb 21, 2015 | Vizio L32 32 in. LCD HDTV
Vizio TV remote controlling Altec Lansing iMT520 dock
Your Altec Lansing dock probably responds to some of the same remote codes as your Vizio TV. Your other TV probably used different codes.
Dec 29, 2013 | Altec Lansing iMT520 inMotion Classic Po
Vizio TV. Can't get out of PHOTO mode. I have no remote. Side MENU button doesn't respond when in PHOTO mode. Need to Hard Reset... How can I?
^_^ Those answers are only for new remote but that's not the only way, There trying to ask in another way with out a remote.
Jan 16, 2012 | Vizio VA26L 26 in. LCD HDTV
Mar 06, 2009 | Vizio VW32L 32 in. LCD HDTV
Code for Vizio tv
It looks like your remote takes a 4 digit code. Try the following codes:
Vizio 0891, 0912,1783
Feb 27, 2009 | Vizio VW37L 37 in. LCD HDTV
Vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Oct 02, 2008 | Vizio VX37L Television
Code for Vizio tv
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Vizio VF550M 55 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
