I have a 1990 coleman 7970 forced air furnace n runs constantly ne dress
    Problem Solver:
  • 11 Answers
MAKE SURE YOUR AIR FILTER IS CLEAN , ALSO YOU COULD HAVE CRUSHED OR DUCTWORK THAT FELL OF ITS PROPER DIFFUSERS FROM CATS OR OTHER ANIMALS UNDER TRAILER. ALSO THE FURNACE IS ONLY EITHER 56000 0R 70000 BTUS INPUT SO IF ITS REAL COLD IT PROBABLY WILL RUN PRETTY STEADY .
Posted on Jan 17, 2014
5 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Posted on May 30, 2008
jcpark50
  • 52 Answers
SOURCE: Manual for a Coleman Forced Air Furnace manual
If you haven't already tried Coleman customer support, try Google. You can find owner's manuals for all kinds of things. good luck, John
Posted on Nov 07, 2008
  • 252 Answers
SOURCE: furnace clicks multipal times while running.Is this normal?
As it starts and stops several switches will open and/or close, sometimes you can hear them. When it's just running then it may make a few noises from expansion and/or contraction.
Posted on Mar 31, 2009
walterkunesk
  • 683 Answers
SOURCE: I have a coleman direct
Question? does it try to start?
Posted on Sep 17, 2011
Testimonial: "was a great help"
My Coleman Direct Vent Forced Air Furnace
First clean pilot , then clean flame sencor this cost nothing only time , check tubes to pressure switch are tight not split of blocked , take asmall drill bit and clean out the connections on the pressure switch some times these can block ,blow it out after you have done this put tubes back on , then check air fitler is clean , you can try and jump ou tpressure switch some times you can fool it in to working , try doing this it may help.
Jan 20, 2013 | Heating & Cooling
Auto fan does not start electric furnace
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
If there is not enough heat, raise the thermostat setting five degrees to see if it turns the unit on. If the unit still does not generate enough heat, check the comfort controls . Clean or replace a dirty filter, clean the blower assembly (see the Forced-Air Distribution Fix-It Guide), and make sure that all registers are open and not blocked.
If the furnace turns on and off repeatedly (cycles), clean or replace the filter; and clean the blower assembly (see Forced-Air Distribution Fix-It Guide).
If the furnace is noisy, make sure access panels are mounted and fastened securely; spray squeaking belts with fan-belt dressing and replace worn or damaged belts; adjust the blower belt; lubricate motor and blower oil ports.
If the element does not heat, refer to the Heating Element Fix-It Guide for guidance.
Oct 08, 2012 | Coleman Mobile Modular Home Electric...
Cant get furnace to run
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Jan 15, 2011 | Coleman Propane Forced Air Heater...
In my mobile home I have a coleman furnace model number 7970-856. It was over 100 degrees today and my furnace fan is stuck running and I don't now if it's supposed to do day. There is no fan switch on the...
There is a fan cycle switch that turns on the fan when the unit heats up (so it won't be blowing cold air) and runs the fan after the unit has shut off to remove heat from the unit. Sounds like it bit the dust. It is located next to the firebox.
Jul 29, 2009 | Heating & Cooling
Coleman Presidential II mobile home furnace. When burner lights the blower cycles on and off instead of blowing constant through burner cycle.
Is this furnace standing pilot or electronic ignition. If standing pilot i would check furnace filter then the thermastat. To test themostat first turn power off to furnace. Take thermostat off wall and take wires labled R & W and connect them together. If you have electronic ignition I would start with cleaning the flame sensor with steel wool or wire brush.If you have and more questions i will be glad to help.
Jan 17, 2009 | Coleman Propane Forced Air Heater...
Nov 07, 2008 | Heating & Cooling
Dec 11, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
