Question about Philips PD700/37 Portable DVD Player - PD700 7" Display DVD Rw, CD Rw, DVDRW Jpeg, Picture CD DVD Video, Svcd, Video CD 16:9 CD Da, MP3, Music CD 1 x Headphone Ports
Take apart philips model pd700/37
Motor want spin, disc does not load does not see disc, disc error
3 Suggested Answers
SOURCE: I need a motor assembly for a philips dvd player
i used to repair dvd and cd players, the motor wont spin until the laser focuses on the disc, so you could have a faulty laser. also the mechanism sometimes comes as a complete assembly. which will cost more than anew unit
Posted on Mar 27, 2007
cammykins
  • 149 Answers
SOURCE: philips dvd783c wont spin.
It sounds like one of the hindge/wheels are off set. Most of the time that can also cause the lazer lense not to come up all the way in order to properly read the disc. When you keep the door open and press start does it allow the lazer lense to come up all the way? That is the small circle glass peice you will see when you look in--some you can see it some you cant.
Let me know.
Thanks.
Posted on Mar 31, 2008
Our Philips HTS3400 DVD player is not working. When inserting a disc, it displays "No Disc". Any suggestions?
seems to be an issue with this model, i cant play any discs, the sound is only coming from the left rear speaker and the sub, the system shuts off every half hour due to overheating...needless to say the system sucks...didnt last long...im very tech savvy and still couldnt figure out why all of this was happening.
im looking at samsung now...everything else i have is samsung and love it.
Dec 31, 2009 | Philips HTS3400/37B System
Tip
DVD PLAYER REPAIR (NO DISC ERROR)
Before you attempt to repair your DVD Player yourself, make sure that you have necessary tools and test instruments like philips screw drivers, multimeter, soldering iron, soldering lead, soldering pump, etc...
This is a DVD/MIDI Player with a "no disc error" upon loading any disc that played before...
Watch this VIDEO
First I've loaded it with disc and observe the movement of the optical lens and the spindle motor. First thing I've noticed that the spindle motor didn't oscillate upon spinning and it's spin slowly unlike the normal RPM...
I've suspected the spindle motor was already bad but still to be confirm...
Unscrew the disc holder plate from the assembly to keep away the magnet touching the spindle motor, this may affect the reading and spinning of the motor upon testing with the multimeter.
This is how it looks like after removing the disc plate holder in the assembly. Spindle motor is secured with 2 small screws in the lens assembly.
Pull-out the connectors from the main board to see the underside of the tray.
You may test the spindle motor with your multimeter set in resistance measurement (ohms X1) even connected to the small board.
Bad motor will read either less than 5ohms(shorted winding) or infinity (open winding) and will not spin.
Good motor will read more than 50 ohms(depends the size) and will spin upon testing. Watch this VIDEO.
Onced you've confirmed that the motor was already faulty, unscrew it from the lens assembly.
Replaced the spindle motor with new one. Before you install the new motor make sure that the clearance of the disc holder is the same as the old one. Compare first the clearance because if it is to high the optical lens will not read the disc same if it is to low....
After replacing the motor re-insert all the connectors to the main board.
I've load same disc which does not read a while ago and observe what will happen. Observe the disc and the sound oscillation from the spindle motor in this VIDEO.
Hope that the above information, pictures, and video will help you fixing your DVD player yourself.
Thanks for visiting Fixya.
Have a nice day!
Jdvillanueva
on Apr 18, 2011 | Bose 3 2 1 GSX System
My player when loading dvd loads for couple of secs and cuts off
Does the disc spin?
If not you have my problem spindle motor suspected faulty if the disc spins then its not being read, faulty lazer assy Try cleaning the lazer using dry brush disc philips do a good one and also clean the disc you are trying to play if it still doesnt work its a fault
Sep 02, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
My dvd palyer shows NO DISC for any disc i want to play.
the laser is probably no good or the tiny motor that spins the disc is no good.there is a clamper assembly that goes in the hole in the disc.turn it and see if it spins freely.there is a bronze bushing on the top of the motor driving it ,and a small drop of light oil on the bearing will make it work again if it is gummed up..if the motor does not get the disc speed from 250 to 600rpm,fast,the laser does generate the proper info and the computer says error.yes the motors can be replaced,but the cost is as much as a new one
Jul 03, 2009 | Philips DVP642 DVD Player
The spin motor doesn't turn spin the disc
yes you can replace your lens also your lens is not working so you have to change
May 18, 2017 | Philips DVP5960/37
Player doesn't recognize DVDs
I hate to be the bearer of potentially bad news, but the problem is not likely the motor. The player attempts to detect a disc present, once that has been completed, the disc will be spun. Since you have the unit open, try cleaning the lens using a cotton swab and alcohol. Next try a music CD. If the CD will play but the DVD will not, the optics have failed and need to be replaced.
Keep us posted.
Dan
Jul 15, 2008 | JVC XV-M567 DVD Player
Disc load error
DVDs spin at constant linear velocity. This means that the disc can be spinning slowly or relatively fast, depending on where the laser is positioned on the disc and what function is being used at the time....accordianman
Dec 18, 2007 | Philips MX3600 System
Mar 27, 2007 | Philips DVP5140 DVD Player
CD Player
You're probably right to suspect the motor, since its not spinning, and the lens is clean. I recently had a "no disc" error that was fixed by general mechanic maintnance- taking apart the lens mechanism, cleaning, oiling and putting back together. If youre lucky it could also be your problem, and it should be a minimum repair fee. Good luck
Mar 13, 2006 | Panasonic SC-AK630 CD Shelf System
Philips PD700/37 Portable DVD Player - PD700 7" Display DVD Rw, CD Rw, DVDRW Jpeg, Picture CD DVD Video, Svcd, Video CD 16:9 CD Da, MP3, Music CD 1 x Headphone Ports Logo
15 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
