Question about Empire Heating & Cooling
Blower fan not working - Empire Heating & Cooling
Gmc 2500 truck work blower does not work at all
Check your fuses for the blower motor. If they are ok, it is probably the blower fan resistor which is located on or next to the blower fan assembly under the passenger side dash in the footwell. if resistor is bad, there will be no fan speeds. make sure you are getting power to fan motor, if power but fan does not work then its the fan. check fuses and fan resistor first. good-day !
Sep 28, 2011 | Cars & Trucks
Heater blower stopped working?
You may want to try your fan on all speeds. If it will work on high, you have a bad resistor for the fan motor. ( high speed doesn't go through the resistor ).
If it doesn't work on any speed, I would check the following;
1. Make sure the fuse isn't blown for the fan blower motor.
2. Check, or have checked the wires between the fan control switch and the fan blower motor.
3. Have the fan control switch checked.
4. Have the fan blower motor checked.
I hope this helps you.
Feb 03, 2011 | 2002 Buick Rendezvous
Heater/defrost/ac does not blow in my 2006 tacoma. worked this morning, parked at work, came out half hour later and would not work.
what has most likely happened is that a fuse has blown that is in your blower fan circuit. Check your owners manual, and see if there is a fuse to that system, if there is, check and see if it is blown. If it isn't, then the problem could either be your blower fan itself, or your blower motor resistor. Generally, when the blower fan goes bad, no speeds of the fan work. When the Blower motor resistor goes bad, usually only 1 speed of the fan works. Try the first suggestion i gave, and it everything checks out in the fuse box, then try all of your fan speeds. If one works, you need a blower motor resistor, if none work, then it is most likely your fan. Let me know how it goes and i'll do my best to assist you further. good luck.
Jan 13, 2011 | 2006 Toyota Tacoma
2005 Chevrolet Silverado - Fan not coming on. When I turn the heater/ac blower fan on, fan does not work. Prior to completely going out, fan would quit working intermittently. Is this a fuse problem? ...
Chk for power at the blower motor electrical connector. If no voltage, check the blower motor resistor, its within the blower motor vent (this controls power to the blower motor). Also, in theses vehicles water may have damaged the blower motor itself. Inspect the blower motor for proper function.
Aug 10, 2010 | 2005 Chevrolet Silverado 1500HD
My fan stopped today. it was working fine and then gone. the rear works fine and I checked the fuses and they all seem fine?
Check the fan relay(or fan module near the blower)or the fan switch itself,or the blower motor is bad,bump the blower motor while the switch,and key are on,if the blower starts working,it is bad.
Apr 01, 2010 | 2005 Chrysler Town & Country
the ac fan blower resistor has failed. The blower will not turn on but the ac clutch works. This is a common problem on several models. You will find on some that the fan will come on and the comp goes off at some settings. Have the resistor checked and verify power to the fan blower before spending a lot of money for a cheap repair. good luck
May 20, 2009 | Heating & Cooling
Saturn 2000 LS2 Blower Fan Problem
You blower fan obviously works. Try replacing the fan speed switch.
Mar 17, 2009 | 2000 Saturn Ls 4dr Sedan
Blower fan not working correctly
It is the blower motor resistor and is located under the glovebox behind the blower motor.
Nov 19, 2008 | 2003 Oldsmobile Alero
Heating & Cooling Logo
480 people viewed this question
Top Empire Heating & Cooling Experts
paulcarew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
