Question about Kenmore Washing Machines
Loud noise kenmore washer
My kenmore front load washer #41743142200 started making a really loud noise. One of the shocks was broken. I replaced both shocks. Machine is still making a loud thumping/chunking noise which is especially bad at the start and end of the spin cycle. It is level. Machine vibrates a little, but does not shake. Is this the bearings or something much worse? how do I trouble shoot it?
    Sergeant:
  • 187 Answers
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Posted on May 22, 2009
When on the spin cycle it makes a very loud noise, what is this
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 02, 2011 | Kenmore 44102 Front Load Washer
Washer makes loud noise during spin cycle
Washer Problems Washer noise when spinning
heatman101
Aug 31, 2010 | Kenmore 4292x Front Load Washer
Replacing shocks on front load washer
through the lower door panel in front of machine. Why???? is machine walking , bouncing or other wise?? This machine spins at HIGH Rpm's so most usual problem is one leg maybe unlevel or possible wood floor maybe "giving " as machine spins and allowing the machine to walk...but then again if machine is "old" shocks could be worn out
May 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
My kenmore 417.42042100 model front loading washer is making a loud banging noise during the spin cycle.
Here's what the problem is.
http://www.youtube.com/watch?v=UwpKP_9_fAA&feature=player_embedded
It's been designed to fail so that you buy an expensive part.
Nov 26, 2008 | Kenmore 46462 Front Load Washer
Kenmore model 970-c44072-00
Probably broken shocks. 50 dollar part but pita to replace
Nov 09, 2008 | Kenmore 43142 Front Load Washer
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Kenmore spin cycle thumping noises
I just went through the same issue with my Kenmore front loading washing machine. I assumed (and a Sears repairman also told me) that it is the bearings. After I took the drum assembly out, I saw the rear drum broken and the inner tub hitting the outer tub. I ordered the outer drum assembly and only when I took the inner drum assembly out I realized the the "Spider" attached to the inner drum (and spindle) was broken. Entire drum assembly cost $417 + shipping and it may be cheaper in the long run to buy a new washer. I like the front loaders because they save water and good for the environment, but the US manufacturers have not yet perfected the technology like European manufacturers (or they don't want the machines to last too long just like cars). Anyway, I am looking into welding the spider tomorrow. If not will return the outer tub assembly and buy a top loading washer for $300!
Dec 07, 2006 | Kenmore 44102 Front Load Washer
Washing Machines Logo
531 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
