Question about Bowflex TreadClimber TC5000
Treadles only go uo and down about 3 inches. Hard to move them
Replaced the cylinders already. feels like something rubbing maybe
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
These are fairly complex machines...call foe service 877-805-1030
Posted on Jan 04, 2014
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: bowflex wont calibration or pass calabration
1= do not panic
2= Lube the deck belt
3= lube the roller bearing
4= adjust the REED switch see the diagram attached, clean and tigh the wires connector very well
5= lube the motor elevation very well gear and shaft.
6= adjust the potentiometer of elevation motor,
7a readjust again the speed sensor, see the diagram attached,clean it and tight wires connector very well.
7= Run again the software calibration for diagnose and troubleshooting
see the block diagram and fix it , maybe the main motor board is faulty, test it with the RUN s.calibration. God bless you
7_8_2012_2_00_09_pm.gif7_8_2012_2_01_02_pm.jpg7_8_2012_2_01_21_pm.gif7_8_2012_2_01_41_pm.gif
Posted on Jul 08, 2012
I have a white treadle sewing machine i want to open to get the serial # but there is something holding from coming up more than 1/2 inch and I am afraid to force it. Any advice?
My white treadle is hard to pull up sometimes. There is a cable that lets the top of cabinet down or open. See (from underneath) if the cable is hung up on something. Here are two websites that can help you too.
http://www.ismacs.net
and
http://sewmachinerepair.com
Both of these are very good.
Mar 26, 2017 | White Sewing Sewing Machines
TC20 treadles will not move after we disconnected pistons and then moved unit when we tried to reconnect pistons one treadles is too far down to comnect and will not move
The treadles can sort of overlap and one gets stuck on the other. Try to carefully grab the front of the one that is higher and pull it away from the other treadle, then it should be able to be lowered. If you have a second person they could pull the lower treadle in the opposite direction. Be careful not to pinch your fingers!
Apr 26, 2014 | Office Equipment & Supplies
Treadles on tc5000 wobble and rub
You have to realign treadles ,take the back cover out and at the base of your unit you'll see two slides , couple of screws and yellow bushings if bushings are still in a good shape you can align treadles , if they're broken or worn out you have to replace them , I think there are 8 of them total ,they're called IGUS bushing
Good luck
Jan 05, 2014 | Bowflex Tc5000 Climber Treadclimber...
The right treadle is rubbing against the right upright why
please see the video and proceed according for fix it.
Please remember to LUBE the deck belt+roller bearing too.
God bless you
Feb 27, 2013 | Bowflex Treadclimber
Bowflex wont calibration or pass calabration
1= do not panic
Jul 08, 2012 | Bowflex Tc5000 Climber Treadclimber...
THE belt that runs top to bottom does not move,do i need a new belt?whats the #?
If the belt is in good shape it may be either a seized drive train or a bad motor. Remove the belt and check to see if the motor runs when the treadle is depressed. Try turning the machine by hand and feel for resistance and listen for grinding, squealing or rubbing noises.
May 13, 2011 | Necchi Sewing Machines
Runs for about 5 minutes and then shuts off
You might have a motor failing. Before you order parts, you need to check some things. Disconnect the electrical power from the dryer. Two spring clips hold the top down on your dryer. Insert a putty knife or a small screwdriver into the crack between the cabinet and the top. About 2-3 inches in from each side is a spring clip. Push in on the clips and they will release the top from the cabinet. Lift the top and let it rest against the wall behind the dryer.
Rotate the drum slowly by hand and listen and feel for hard places. The drum should turn smoothly and fairly easily. You will be turning the motor and the blower wheel as you rotate the drum and if something is inside the blower housing you should hear it rubbing or moving around.
If nothing is wrong in the blower wheel or the drum bearings, the motor will be your problem.
Jan 13, 2011 | Dryers
Bowflex Treadclimber rubs against housing.
Adjustment is needed. Remove rear covers and using a 9/16 wrench lossen the four bolts that secure treadle assembly to base. Place a 3/4 inch piece of plywood or a 3/8 inch socket extension in between the treadles in the front area. with that in place center them about an 1/8 in closer to the right upright as when you tighten the four bolt up the drive belt will place additional pressure and they should center perfect. tighten bolts...tight. remove wedge from between treadles and recalibrate unit. replace covers and enjoy. Use turtle wax on area rubbed to prevent rust.
Mar 05, 2009 | Bowflex Treadclimber TC5300
1989 honda prelude s clutch problem, I can put the clutch pedal down, feels like its working ok, slave cylinder moves the clutch fork the normal distance, yet the clutch never disengages, i changed all the...
prolly a hydraulic problem master os slave cylinder leak ck your fluid takes dot 3 brake fluid , also you can put in gear hold the pedal down usually if the fiber substance is gone from the clutch disk the car will not move while cranking if the car moved then its a hydraulic problem , note to self try this with nothing in front of the car it might start up in gear if that happens you will have to immediately turn the engine key off , if the fiber is gone while running you can put trans into any gear while running without pedal inguaged , hope this helps
Dec 19, 2008 | 1989 Honda Prelude
Hydraulic clutch for jeep wrangler 2000
hello usaully it is on the slave if not try to hold the clutch pedal in overnight with a stick or something take the cover off the master for the slave so air can escape thru the top goodluck
Sep 18, 2008 | 2000 Jeep Wrangler
Bowflex TreadClimber TC5000 Logo
283 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
