Question about Husqvarna Viking 1
Needle positioning the needle moved and is hitting the metal plate. don't know how to reposition it
    Champion:
  • 243 Answers
Start with a new needle. Next check the needle plate is installed properly.
Posted on Jan 30, 2014
4 Suggested Answers
  • 192 Answers
SOURCE: needle seems to be hitting the plate and sounds
First you should try a new set of needles. It is very common to bend needles in a serger.
I don't recommend that you ask a Husqvarna technician to align the sewing head since there is no sewing head alignment in a 900 series Huskylock ( or any Huskylock that I know of). The upper adjustments are needle bar height and needle bar twist. As long as the needles appear to set side by side, you probably have no twist so this isn't causing the needle to hit. Do remember that the needles appear to be different lengths. This is normal.
Remove the plate and see if the needles are hitting something else underneath.
But always, ALWAYS change the needles first. They're cheap, easy and fast.
Posted on Feb 16, 2010
  • 51 Answers
SOURCE: Can't find the manual for the Husqvarna Viking
http://www.tradebit.com/filedetail.php/87838064-husqvarna-viking-emerald-116-118-122-user
Posted on Sep 17, 2010
SOURCE: needle hitting stitch plate on my Viking Lilly 545 recently had it serviced, was sewing fine
try a new needle
if the needle is still hitting the needle plate, then it's possible that the machine is out of time and needs to be adjusted, or there is something wrong with the needle bar.
Posted on Nov 13, 2012
My needle is hitting the metal plate on a singer cg590 sewing machine. Is there a way to adjust it back into its correct position?
Your needle plate may have been place incorrectly, and it's easy to do. Even the slightest variation can cause the needle to hit it. Try taking the metal plate off and then reseating it -- testing the needle position before you tighten the screws.
Dec 18, 2016 | Singer Sewing Machines
I know how to attach my ruffler foot but my needle keeps hitting the plate .what do I need to adjust to keep the needle from hitting the foot
You may need to move the needle position left or right. Try a different stitch length. If the ruffler foot is installed correctly and needle is in the correct position this should not happen. It is hitting left/right/forward or back of the ruffler needle space?
Sep 13, 2014 | Sewing Machines
My needle on my scandinavia 400 moved and is hitting the metal plate. I dont know how to reposition it
Put in a new needle. If that doesn't help, check to see if the needle plate is loose.
Jan 03, 2014 | Husqvarna Viking 1
Needle breaks because it hits the area around the bobbin.
Here are a few things to check. You may have checked some of these already but it may be worth checking again.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but check your manual), make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics, switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 30, 2009 | Sewing Machines
I have broken 2 needles and now the new needle (foot) will not move up and down. i have double checked all settings and nothing has helped. any suggestions
Here are several solutions for you to try.
* Your broken needle may have been too thin for your fabric. Make sure your replacement needle
is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric. When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot to make sure it’s attached securely.
* Change your pressure foot. Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins. A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate to make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle, right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 23, 2009 | Bernina Artista 180
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Check your needle plate and make sure it's securely in position.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Keep breaking needles
Here are some solutions to try.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
When i use my janome overlocker the needle is hitting the lower looper, and therefore breaking. This is happening with both needles. I have taken the covers off and the needles are hitting the metal. Is it...
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
your needle.
pressure foot.
I hope one of these solutions help you.
Sep 14, 2009 | Sewing Machines
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    If this doesn’t seem to be the problem
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Sewing Machines Logo
60 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
