Question about GE JBP30 Electric Kitchen Range
SOURCE: F4 code when preheating oven
That code means "Shorted Oven Sensor". You can find out more about this by removing the bottom drawer, pull it out til it stops, lift it up and pull it all the way out. Now lay down on the floor and look under the oven to the left side. You will see a service info card there. Pull it out, open it up and have a read.
Posted on Oct 17, 2007
SOURCE: ge gas oven/ranger xl44
The F2 is the code for the board seeing a temp higher than 600 degrees. It could be one of two things. The temp sensor is out of range, extreme high resistance. If you ohm it out it should read approx 1100 ohms at room temp. The other would be a welded bake relay on the board itself. Check the temp sensor first. If you are getting the F2 in the cleaning cycle, check the temp sensor, welded clean cycle contacts on the board or both contacts on the lock switch are closed at the same time. This is for the model posted JGBP90.
Posted on Nov 24, 2007
SOURCE: Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Posted on Feb 04, 2008
SOURCE: GE gas stove
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)as far as the heat from under the clock assy thats the normal vent( nedds to release heat somewhere, not a problem
Posted on Oct 07, 2008
SOURCE: items are not baked all the way through
Put a thermometer in the oven to see how the temp is vs what you set it at. If temp is off by more than 25 degrees replace the oven sensor. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
Oct 28, 2017 | DeLonghi Ovens
Mar 14, 2016 | Microwave Ovens
Dec 02, 2015 | Bosch HDI7152 Stainless Steel Dual Fuel...
Mar 09, 2014 | CorningWare Microwave Ovens
Apr 07, 2011 | Ovens
Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
Dec 14, 2008 | Ovens
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Aug 06, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Dec 17, 2006 | Roper FEP310 Electric Kitchen Range
24 people viewed this question
