Question about Konica Minolta Office Equipment & Supplies
C-2557 malfunction detected please call your technical representative
  • Konica Minolta Master
  • 1,294 Answers
C 2557 - ATDC sensor error.You need to replace the developer in imaging unit.
Posted on Jan 03, 2014
sir fixalot
  • 146 Answers
SOURCE: Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Posted on Jan 04, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Error C3451 ! Anyone? Pretty Please.
This is an indication of a reoccurring error or faulty part. You MUST place a service call.
Posted on Jan 08, 2008
SOURCE: Konica Minolta Error code C-D351 on a Bizhub C250
Hi
I have come across this kind of problem.
Is your BizHub on the network? If yes, please switch it off completely, and take the Ethernet cable out of the BizHub.
Wait for atleast 30 seconds and reconnect the cable. Now start the printer again and see if the error message goes away.
Hope this helps!
Posted on May 21, 2008
SOURCE: Errorcode c-2555
Good morning,
Just had the same problem & it was low toner density on the yellow toner. We told to change the toner or shake the existing one & put it in again.
hope this helps.
Posted on Oct 14, 2008
  • 12 Answers
SOURCE: Error message C4551 anyone? pretty please.
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Bye.
Posted on Dec 28, 2008
Cobao
Your Exit trays hit something did some one leave a trash can or boxes under the exit trays!!!!!!!. Now you need to get a Qualified Konicaminolta tech out to reset the output trays to there proper positions, have to remove the Elevation drive system with out the trayas slamming into the bottom of the finisher, quite complex to do that why I recommend a qualified tech
May 22, 2013 | Minolta Di3010 Copier
Code malfunctios c1441 minolta di 450
The copiers CPU is equipped with a self diagnostics function that on detecting a malfunction,gives the corresponding malfunction code on the touch panel.Resetting a malfunction:
- Press the trouble reset switch on the technical representative setting switches board to reset fusing and exposure lamp related malfunctions.(code: C400,410,420-expo;C500,510,520-fusing unit)
- For any other malfunctions,open and close the front door or turn OFF and ON the power switch.
C1441 CCD failure(clamp adjustment failure).
Reset the malfunction,check that the original glass is properly installed.Check for extraneous light and check to see if CCD Assy and mirrors are installed at the correct position.If the same malfunction is detected again,change image processing board.
Aug 14, 2012 | Office Equipment & Supplies
A Malfunction was detected. Please call your technical representative and provide code. C4553
CAUSE: Failed laser unit (C4551 - Cyan; C4552 - Magenta; C4553 - Yellow; C4554 - Black).
SOLUTION: To confirm the failure of one of the laser units, perform the following:
1. Power the copier OFF and remove the power cord from the wall.
2. Switch the position of the laser unit with one of the other laser units.
3. Plug in the power cord and power the copier ON.
4. The failure code should change dependent upon the new location. Replace the laser unit as necessary.
Jul 24, 2012 | Minolta Di251 All-In-One Printer
Konica minolta Bizhub C350. Following message appeared on my printer: Malfunction detected. Please call your Technical Representative and provide code: C-0F36 What does this code mean?
Hi katienash,
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.
Good luck
Regards
m-press.biz
Jan 25, 2011 | Konica Minolta Minolta Printer stand...
Printer says "Malfunction detected Please call
What code is showing? and what model are we talking about?
Jan 04, 2011 | Minolta Office Equipment & Supplies
Whenever i try to photocopy it states that malfunction was detected please call your technical representative and provide code...........cof32
What is the MAKE & MODEL? I'm guessing you have a Minolta??? You need to clean the drum unit & the ATDC sensor or replace the OPC
Sep 15, 2010 | Office Equipment & Supplies
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Bye.
133 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
