Question about Dymo Labelmanager Lm 160 Handheld
Dymo labelmanager 160 Label jam
Press print and does not print, displays Label Jam
  • 28 Answers
SOURCE: dymo label 400 turbo.
THERE MUST BE PROBLEM IN THE INK OF THE PRINTER CHANGE THE INK N U WIL NOT FACE IT AGAIN
Posted on May 24, 2008
SOURCE: Not printing at all. Screen appears as series of exclamation marks
I had the same problem with my label marker. Changing the batteries fixed the problem
Posted on Jun 28, 2008
SOURCE: CONTINOUS FEED
Use a DYMO Label/Writer Cleaning Card #60622. One should have come with your printer. Just remove the labels, run this cleaning pad through a few times, insert the labels, and print.
Posted on Sep 16, 2008
  • 126 Answers
SOURCE: Dymo LabelManager 300
I would suggest reinstalling the driver.
First disconnect the label writer, then go to :
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=101
Scroll down and you will see your model number and download the drivers. Then run the installation again and it should prompt you to connect the label writer, which should fix the problem
If not also try reinstalling the "Label Software Application" listed on the same page as well.
Posted on Jul 15, 2009
  • 14 Answers
SOURCE: my dymo label printer is printing 2 labels at a
There are a few common reasons this is problem can exist.
1.) the incorrect template is used when creating the label
2.) the labels are installed incorrectly - the labels must be loaded and pushed against the left side of the printer and lid closed when printing to ensure the labels don't "wander" out of the sensor's view.
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view.
4.) The labels are defective - if you have another roll of the same size, try it to see if it has the samme issue.
Posted on May 06, 2010
My dymo labelmanager 9000 will not print labels, a comment comes up saying label with arrows pointing to the left each time i press the print button. i have tried pressing the bottom feed button...
The fix for this involves opening the unit up. The problem is the infra red LED sensor on the label exit has slightly miss-aligned giving the error. If you unscrew the two sensor boards, re-align and screw them back all will be well.
Hope this helps.
Jan 10, 2011 | Dymo LabelMANAGER 9000 Printer
Displays !!!!!!!!! when you say print
This means there is a paper jam. Clear the paper jam and i should work fine.
Jan 16, 2010 | Dymo LetraTAG Thermal Label Printer
My dymo label writer twin turbo stopped printing on left side!
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. 4.) the print head is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view.
5.) The labels are defective - if you have another roll of the same size, try it to see if it has the same issue. If not, make sure you purchase quality labels like Dymo name brand or Labelvalue brand Dymo labels.
6.) The printer is defective. Labelwriter 400s have a 2 year warranty, so you can contact Dymo customer support to determine if the printer is defective and return to the retailer you purchased it from.
Oct 08, 2009 | Dymo LabelWriter Thermal Printer
Cannot get dymo to print vertically
On mine you use the FORMAT button
Then theUP arrow until you see STYLE
Then press OK
Now press the UP arrow until you see VERTICAL
Now press OK
Sep 15, 2009 | Dymo LabelMANAGER 450 Printer
Jul 15, 2009 | Dymo LabelManager 300 Desktop Labelmaker...
Tape Jam
There may be a small piece of label cutting stuck in the gears. remove the label cartredge, you will see a white gear set between the pinch wheel and the print head. Use a micro drive or something strong and give the gears a little help while pushing the print button. You may have to do this several times. Be careful not to use too much force as this may knock a tooth off. Good luck. My Dymo continues to print prefet labels.
Mar 08, 2008 | Dymo LetraTAG Thermal Label Printer
Jan 08, 2008 | Dymo LabelManager 300 Desktop Labelmaker...
Printing
I was having the exact same problem & had lost my user's manual (you can go on the Dymo.com website to download a replacement). The !!!!!!!!!! display means that there probably is a tape jam. Here's what the manual says:
*!!!!!!in the display indicates that the tape can not be transported *Press any key to return to normal display *Check if there is a tape jam. In that case, life out the cassette and carefully release jammed tape. Cut off excess tape and refit/replace the cassette *If there is no tape jam replace the batteries
Nov 05, 2007 | Dymo LetraTAG Thermal Label Printer
Dymo Labelmanager Lm 160 Handheld Logo
364 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
