Question about Honeywell HE360A1027 Whole House Humidifier Humidifier
HONEYWELL HE260 WE HAVE A TWO STAGE FURNACE WITH A HONEYWELL HE260 HUMIDIFIER INSTALLED. OUR PROBLEM IS THAT THE HUMIDISTAT TURNS ON AND OFF MANUALLY HOWEVER ON AUTOMATIC THE WATER CONSTANTLY FLOWS EVEN WHEN THE FURNACE TURNS OFF. WE HAVE TWICE REPLACED THE SOLENOID HOWEVER THE PROBLEM STILL EXISTS. HOW DO WE FIX IT.
  • CEBEAU Nov 26, 2007
    YOU WERE WRONG. IT APPEARS WE HAD TWO PROBLEMS. THE FIRST WAS THAT WE NEEDED A STEP DOWN TRANSFORMER AS THE SOLENOID WOULD ONLY WORK PROPERLY AT 24 VOLTS. IT SEEMS THAT THE FURNACE CO. THAT INSTALLED OUR FURNACE FORGOT TO PUT IN THE TRANSFORMER SO THE SOLENOID WAS OPEN ALL THE TIME AND EVENUTALLY WAS UNABLE TO CLOSE COMPLETELY SO THAT WATER CONTINUED TO FLOW THRU IT CONSTANTLY EVEN WHEN YOU MANUALLY CLOSED IT. AFTER PUTTING IN THE TRANSFORMER WE FOUND OUT THAT THE SOLENOID WAS NOT CLOSING COMPLETELY AND WATER WAS STILL RUNNING THRU IT. SO WE DID NEED A NEW SOLENOID.
    ALSO, THE CURRENT SENSING RELAY WAS ALREADY BUILT INTO THE BOARD IN THE FURNACE SO IT WAS NOT NECESSARY TO INSTALL ONE.
  • 363 Answers
Unless you are using a current sensing relay or sail switch, you need to get the humidifier power from the blower motor supply so it only operates when the blower is on.
Since you can manually control the humidifier, there is not a fault with the solonoid.
Posted on Oct 19, 2007
  • Martin B
    Martin B Nov 28, 2007
    First the solenoid valve should have been rated at your line voltage. Your installer was an idiot.
    Secondly, although a step down transformer (could) have cured the problem, the solenoid valve was actually burned out by over voltage and it ceased to work within a few minutes of operation causing the water to keep running.
    I hope the replacement solenoid is rated at the correct voltage now so that you do not need a transformer.
    Since I do not posess supernatural remote viewing powers to know that the installer had put in the wrong voltage solonoid then I feel totally vindicated.
    Please do not blame me for your incompetent installers mistake with the voltage rating.
    Fair enough?
    P.S. stop SHOUTING and use lower case letters following the first letter of a sentence. You are more likely to obtain help that way.
    If there is anything else we can help you with then please reply and my collegues and I will try our best.
    Regards
Wire Honeywell HE220 to N8MPN/L, *8MPN/L furnace control board
HI
I have similar isssue with HE220 but in my case the water run through all ththe time, even when unplugged from the power outlet.
Would that be solenoid issue?
the unit run fine for last season so the wiring is fine.
Any ideas would be greatly appreciated.
Jan 22, 2012 | Honeywell HE220A1019 Whole House...
I installed a honeywell 360a flow thru humidifier, and a new transformer. I have power thru the wires to the fan cover. Also the humditstat clicks when turned on. The fan does not work and the solenoid...
Posting a diagram of how you wired the installation will help the both of us figure out what the problem is. You don't have to accept or rate this solution in order to post comments or information. But accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Jan 11, 2011 | Honeywell HE360A1027 Whole House...
FROM A CONDO IN FL WITH HEAT PUMP---I HAVE A WHITE-ROGERS THERMOSTAT (2 STAGE HEAT-1 COOL) AND WANT TO WIRE IN A HONEYWELL H46C HUMIDISTAT FOR HUMIDITY CONTROL. THERMOSTAT HAS THE FOLLOWING WIRE POSTS E O...
It's a little unusual to add a humidifier in Florida. The ambient humidity is usually high enough.
But anyway, if you want to do this and assuming you have central air with forced air heating, you could install the humdifier in a standard configuration, then use a sail switch or differential pressure switch in the supply air duct to turn the humidifier off or on when you are in the heating mode only. The sail or differential switch will ensure that the unit can't run unless air is moving and you can tie the humidistat in to the first heat stage.
Mar 05, 2010 | Honeywell Power Humidifier: Furnace...
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Honeywell HE260 housing melted/deformed
Humidifiers are made from a very durable heat resistant plastic. If it melted or warped you have a serious overheating problem. That plenum should not get over 140 to 155 degrees. If this furnace is running to hot it could stress and crack your heat exchanger. Install a good carbon monoxide detector in your home!!!! Check your filters. Check your airflow. Make sure all registers in the house are open. Is your blower speed set high enough? If this furnace is operating to hot it is definitely worth the investment to have a pro look at it before you replace the humidifier.
Is this overheating problem new? Or was this something thar happened years ago and may have since been solved But you are just now noticing the heat damege that was caused.
Goog luck
HVAC Teacher
Mar 07, 2009 | Honeywell HE260A1010 Whole House...
Wiring issue with the Honeywell HE360A Humidifier
Maybe I can help. this is 24v so it doestn't matter which wire goes where so here goes. 2 wires from humidistat go to furnace, split one of the wires(not both) so they reach the yellow wires on the humidifier. with marettsconnect one of the split wires to one of the yellow wires. do the same to the other split wire and yellow wire. what you should get is one wire from humidistat to furnace then one wire from humidifier to humidistat and one from humidifier to furnace. hope this helps
Jan 31, 2009 | Honeywell HE360A1027 Whole House...
Humidistat installation question
I suppose you are looking at the do-it-yourself model. Depending on the wire that is run up to you Regular Thermostat from your furnace. You may have to run a seperate line for the Humidistat. A digital thermostat that does Humidity and Temperature is recommended. Or you could just place a Humidistat near the furnace room. A wiring diagram will come with the Humidifier discribing the different ways to wire it.
Jan 09, 2009 | Honeywell Power Humidifier: Furnace...
Wiring problem
Sounds like you may have put 120v through a 24v solenoid and humidistat.
Is the HUM terminal on the furnace 120v or 24v?
If it is a 120v terminal you will need a 120x24v transformer and a new solenoid and maybe a new humidistat.
Dec 19, 2007 | Honeywell HE360A1027 Whole House...
Honeywell HE360A1027 Whole House Humidifier Humidifier Logo
355 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
