Question about Sony DCRSR68 Camcorder
View nef files in PlayMemories - Sony DCRSR68 Camcorder
Convert NEF format to JPEG
You can use the Nikon View program that should have been included with the camera. or you download the current versions of Nikon ViewNX or Nikon Capture available free at Nikon Imaging Products Software
Dec 11, 2016 | Nikon D Cameras
How to work on nef files and convert into jpeg files
There are several ways to open NEF files.
With the appropriate codec, Windows can open NEF files for viewing:
http://support.nikontech.com/app/answers/detail/a_id/13869
Recent versions of Adobe Camera RAW can open NEF files and allow you to work with them in Photoshop and Photoshop Elements (this is not free software):
http://www.adobe.com
The free Nikon ViewNX2 can open NEF files and convert them to JPEG. Nikon CaptureNX2 allows you to work with the NEF files directly, though this is also not free software:
http://support.nikontech.com/app/answers/detail/a_id/61
Jan 17, 2011 | Nikon DSLR D90 Digital Camera
I cannot open NEF files with Adobe elements, so what programma do I need in order to open these files? The photos were taken with a Nikon D70 as RAW files, and transferred to my laptop which runs on...
You can use Adobe Photoshop to edit the files in the nikon format or if you just want to view them you could use a .nef to .jpeg converter. I found one that will convert a batch of .nef files to .jpeg by just dragging and dropping them. You can find that here: http://www.reasoft.com/rea-nef-convert.shtml
Oct 14, 2008 | Computers & Internet
Nikon NEF files no longer open in cs2
hi dear
The Nikon NEF Plug-in for Photoshop
(In Windows, search "plug" to find "P2_NEFPlugin_En.pdf" in the NikonPictureProjectReferenceManual folder. You should have copied this manual to your HD from your PictureProject CD when you installed PictureProject.)
D40x NEF Photoshop Plugin -
file: "Nikon NEF Plugin LE.8bi"
Search Windows for "*.8bi"
These two plugins can be found at C:\Program Files\Nikon\PictureProject
Follow these instructions for (taken from the above reference manual)
  • **Note: before you uninstall PictureProject back up all of you NEF files.
    "Installing the Nikon NEF Plug-in
    Two Photoshop plug-ins are included with PictureProject: a Nikon NEF Plugin LE plug-in for viewing RAW images, and a Nikon YCC TIFF plug-in for viewing YCbCr-TIFF images (in Windows, these fi les have the extension “*.8bi”). These plug-ins can be used with Adobe Photoshop Elements version 2.0 or later and with Adobe Photoshop version 6.0 or later (Windows) or 7.0 or later (Macintosh). Both plug-ins are copied to the PictureProject application folder when PictureProject is installed (in the Macintosh version, the plug-ins are copied
    to the “File formats” folder in the PictureProject application folder). If a copy of Photoshop is detected at installation, the plug-ins will also be copied to the Photoshop plug-ins folder. Users who install Photoshop after installing PictureProject should fi rst uninstall PictureProject, and then reinstall PictureProject when installation of Photoshop is complete."
    After you open the RAW NEF picture file in Photoshop save it in lossless .psd format for further editing.
  • oke
    cropp
    Mar 19, 2008 | Adobe Photoshop CS2 for PC
    How can I use the Adobe Camera Raw plugin after installing Nikon Software?
    During the installation of Nikon View or Picture Project, your system is checked for an installed copy of Adobe Photoshop. If a copy with the minimum version is found, Nikon View will install file format filters which will allow Photoshop to open a NEF/RAW file directly (there are other plugins for YCBCR TIFF format from supported cameras). If you have the Adobe Photoshop "Camera Raw" software installed (optional in Photoshop version 7, included in Photoshop version CS) the Nikon file filters will open the file. If you prefer to continue using the Adobe software, find and remove the following plugins: Nikon NEF Plugin (Nikon View) Nikon NEF Plugin LE (Picture Project) After a restart of Adobe Photoshop, the Adobe Photoshop "Camera Raw" plugin will handle the opening of Nikon NEF/RAW format files. Please note that there was an update for Adobe Camera Raw plugin for support of D70 and Coolpix 8700 RAW files, if you encounter difficulty opening raw files from any Nikon product after removal of the Nikon Plugins, please visit the Adobe support site to obtain the appropriate update for the Adobe Camera Raw plugin.
    Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
    NEF Image will not open - Macintosh
    RAW NEF images from Nikon cameras are proprietary formatted raw data directly from the cameras's sensor. If the images are improperly transferred to the computer they will not be able to be opened and will give an "Unsupported File Format" warning. Macintosh OS X has an "Image Capture" application (found in: Hard Drive/Applications/)that can be used to transfer images. If "Image Capture" is used NEF files will be corrupted and will not be able to be read. Only Nikon View, or manually dragging images from the mounted card, should be used to transfer NEF's. To disable "Image Capture": Double-click to open the hard drive and then the "Applications" folder Double-click "Image Capture" From the "Image Capture" menu choose "Preferences..." In the "When a camera is connected" pop-up choose "No Application" Close the Preferences window and Quit Image Capture After disabling Image Capture, it will not launch when the camera is connected and you can use Nikon View to properly transfer NEF images.
    Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
    Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
    Sony DCRSR68 Camcorder Logo
    96 people viewed this question
    Top Sony Video Cameras Experts
    Larry Stiles
    Larry Stiles
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Video Camera Expert? Answer questions, earn points and help others
