Question about Azpen A9 Android Tablet
Authentication problem with WiFi connection on Azpen A9 tablet
Authentication problem. Reset wifi and tablet. Nothing is working.
An "authentication problem" means that that the wifi does not accept the wifi password that the device is providing, or that its MAC address may be on the exception list, not allowing it to connect. Verify that the tablet is using the proper wifi password for the system you are trying to connect to, and that you are using the same wifi security (WEP/WPA/WPA2) on the tablet that the wifi is using.
Oct 04, 2015 | Dragon Touch Touch R10 10.1 Google Android...
My tablet screen is frozen on the screen that reads azpen.when i turn it off and back on it is still frozen.it will not take a charge nor if i leave it on will the battery die.what can i do?
Hard Reset
Press Vol-up&Vol-Down button at same time, Then press the power button.
This starts your devices Recovery Mode.You can do a Wipe/Factory Reset from there. Use the Vol Up&Down buttons to navigate and the power button to select.
Be Careful and DONT MESS with the Other options or you may Brick your phone.
Apr 12, 2015 | Azpen 03038 A9 9.7" 8gb Android tm 4.0 Os...
Why can't I update my tablet? I have a good wifi and internet connection. I have reset my tablet
While I am not fully knowledgeable about your tablet, many need sufficent memory before an update can be preformed. I would make sure you have the proper space requirements.
May 15, 2014 | Azpen A9 Android Tablet
No sound volume when volume is high
Go to www.techspot.com
They have several troubleshooting techniques for you to try.
Mar 18, 2014 | Azpen 03038 A9 9.7" 8gb Android tm 4.0 Os...
How do I get Tablet fix it will not charge?
The mini USB cable that came with my tablet was lame and would only charge if held at a certain angle. Another cable worked fine. This is an ultra cheap tablet, and they cut corners everywhere they could.
Jan 09, 2014 | Azpen A9 Android Tablet
Wont download candy crush it says it's not suppoted
Do a system update,or perform a reboot. Press and hold power button til phone goes off and comes back on. If that doesn't work, go to www.techspot.com
Nov 16, 2013 | Azpen 03038 A9 9.7" 8gb Android tm 4.0 Os...
How to view wifi address on msi tablet
How can I connect to Internet on my MSI Tablet, it keeps saying "Obtaining IP Address"??????? PLEASE HELP!!!!
Jan 19, 2013 | MSI 10 Nvida Tegra 2 Cortex-A9 Android 2.2...
Authentication problem connecting to wifi
Can't get unit to connect to my home wifi , keeps giving message Authentication Problem
May 12, 2012 | Polaroid Tablet Computer PMID701
Azpen A9 Android Tablet Logo
79 people viewed this question
Top Azpen Tablets & eReaders Experts
 Mikey
Mikey
ray gallant
Outback Jack
Outback Jack
Are you an Azpen Tablet and eReader Expert? Answer questions, earn points and help others
