Question about Craftsman Tools & Hardware - Others
Router will not run - Craftsman Tools & Hardware - Others
Error 322
Are you trying to run the CD that comes with the router?
I think you can try to setup your router manually instead of running CD. WRT160N router has issues with the firmware so I will suggest you to upgrade the firmware of WRT160n router first.
See how to setup Linksys WRT160N router
Jan 08, 2012 | Linksys WRT160N Wireless Router
How do i install a router
Use quick start guide. If not plug in router. run USB cable (should come with one), or run cat5 (ethernet cord) from modem to router. then run ethernet cord from PC to router. Plug cord from modem to router in first port. plug cord from PC to router in any other port. Should be good to go If you have a software disk you should run it first and it should prompt you with instructons.
Good luck
Oct 15, 2010 | Computers & Internet
Bridge router
1. Use both the Modem and the router as NAT routers. Do this by making your router a DMZ node on your modem, that way ALL traffic will pass to the router, then set up port forwarding etc on the router.
2. Run the router/modem in bridge mode (recommended). You need to set the modem to run in bridge mode, check the user manual for refrences to bridging. Then set the router to connect to PPPoE using a username and password.
Jun 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
Bandwith failing with quest 2wire 2700hg-d router use to be able to run 3 pcs on it now can hardly run one
Check if the Firmware of the router is updated or not, if not then update the firmware first and then run the Router diagonostic tool to check the bandwidt allocation.
Mar 16, 2010 | 2wire (1000-400108-001) Router
Cannot run smart wiszard to install router
Yes. Plug everything in and turn it all on. Then run the Smartwizard.
Nov 28, 2009 | NetGear WGR614 Router
How to instal D-link
Read the "Quick Install Guide" that came with the router.
Or, connect an Ethernet cable between your ADSL/Cable modem to the 'WAN' port on the router.
Connect another Ethernet cable between LAN port #1 on the router and your computer.
Turn the router on.
Restart your computer.
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
Look for a line like:
Default Gateway . . . . . . . . . : 124.168.136.111
Start Internet Explorer.
Type http://124.168.136.111 and press ENTER.
Login to the router's web-interface.
Run the "Wired Setup Wizard".
Run the "Wireless Setup Wizard".
Nov 16, 2009 | D-Link DIR-655 Wireless Router
I need to hook my wireless router to pc and I can't get a connection after i do it. What Do I need to do?
make sure that your cables r connected correctly, just swap them around internet and ethernet on the back of your router. Also make sure u run your software wizard that came with the router. also the cable that is running from the back of your computer should connect into router internet port then your ethernet cable should run from router to dsl box
Nov 07, 2009 | Linksys Wireless-G Broadband Router
3 netopia 2247 routers daisychained
How far are you running the CAT5 cables from house to house?   CAT5e only has a solid range of about 150ft, and anything near 100ft is pushing it.  You may also need to use CROSSOVER cables when plugging routers into other routers.
Also, who has the actual internet connection?  I'm assuming House 2 does.  One big problem is a router is your Gateway address.  And, if house 2 is the only one with a valid Internet connection (via DSL or Cable, etc), then the router in house 2 is the only "true gateway".  And, all 3 houses need to be in the same physical network (i.e. 192.168.1.0 range or whatever), and all computers should have the same Gateway address...which would be the IP address of the router in House 2.
What you really need in this situation is 1 router and 2 switches.  Put the router in House 2 and put switches in House 1 and 3.  That would be the best way to handle this problem.  It would also end your connectivity problems.
Cheers!
Jul 11, 2008 | Netopia 2247NWG-VGx Wireless Router...
Dynes Wireless G Router
Try turning everything off, PC, Router, and Modem. Then turn on the modem, then the router, then the pc. Your modem needn to connect, then the router will be assigned an ip address, then your pc will acquire an ip from the router.
Jan 14, 2008 | Computers & Internet
Tools & Hardware - Others Logo
12 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
