Question about Kenmore Series 70 80 90 PN281798 Dryer Motor
Dryer makes noise while rotating
Everytime I start the dryer it makes a noise as it rotates. It seems to be in the beginning. Maybe it is a belt or something that needs replaced.
  • 213 Answers
SOURCE: how do I replace belt on kenmore dryer 66512?
under the lint screen on the top of the dryer there are 2 screws. remove these screws. aong the edge where the front of the top of the dryer meet the top of the front of the dryer there are 2 clips. press in the clips with a putty knife to raise the top. look inside you will see 2 screws that go into the front of the dryer. remove thoughs screws and the front will lean forward and lift off. there you will be able to put belt around the drum, tension pulley and motor pulley
Posted on Nov 28, 2007
  • 91 Answers
SOURCE: kenmore dryer hums but will not rotate
PRETTY OBVIOUS REPL/ MOTOR
Posted on Jan 03, 2009
  • 5 Answers
SOURCE: Dryer won t heat 100 74732400 model
dryer element. Common problem easy repair.
Posted on Jun 07, 2009
TheMobilian
  • 8220 Answers
SOURCE: drum not rotating on kenmore 80 seires gas drier
Some repair pix with manual
Posted on Sep 09, 2009
  • 21 Answers
SOURCE: My kenmore elite dryer make a loud squeaking noise
It could be the drum bearing or the idler pulley is worn out.l
Posted on Feb 14, 2010
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
Dryer is frozen wont rotate when i hit the start button just makes noise then shuts off
The first thing I would do is try to rotate the drum by hand, there should be a little resistance at first, but once it begins to rotate it will rotate more easily. If it spins with no resistance it could be a broken belt or belt has slipped off. The noise I think your hearing is the electric motor trying to start up and may be locked up, and then tripping its thermal protection and shutting it down. These motors are durable but won't last forever, and are exposed to a lot of dirt and lint and can get packed in and around the motor affecting its operation. It doesn't sound like an easy fix to me other than a motor replacement. Hope this helps good luck.
Sep 09, 2012 | GE Profile Harmony DPGT750EC Electric...
Hi, Thee dryer makes a loud noise during cycle. It starts low, but it seems after each rotation it get louder. Has anyone ever experienced this and are there any solutions. Thanks for any assistance.
Describe the noise. If its a rattling banging noise you could have a broken exhaust fan which is usually attached to the motor, a broken cylinder roller (if your dryer has them) or worn felts. Maybe a noisy pulley. If its more a high pitched squeek it could be your motor or the parts just mentioned. A metal scraping noise could be something like a bra wire caught by the cylinder but I don't see how that can get louder as the rotates. Make sure the belt isn't cracked all over. Worst case scenario is that your motor is on its way out...
Good luck
Aug 29, 2010 | Dryers
Dryer makes a sound as if there's a marble loose in some rotating part. It doesn't seem to be coming from the drum, because when I disconnect the band from the motor and hand rotated the drum at speed...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ghhgfhf
Mar 21, 2010 | Kenmore Elite HE3 Steam 8676 Dryer
Dryer rotates and drys well, but makes a noise when reversing rotation. Makes more noise at the beginning of use, then subsides. What could be wrong? Belt, bearings? Can I fix or do I need an expert?
heatman101
fsjhgf
Nov 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
My dryer has power but the drum will not turn
Belt, Motor, motor start capacitor or Door switch. you going to have to open the back cover off and see what is taking place. check belt making sure good and tight, idler pulley may be worn also. If motor only making a hums sound when you press start it may be burnt out. you can check if the motor is good or bad by removing the belt and manually rotate the shaft motor pulley, if the motor is stiff and impossible to rotate manually, it also a sign the motor burnt out. if the motor turn and run freely without the belt, the problems maybe with the pulley or the drum, try to rotate the drum and making sure it rotate freely using very little effort. if door switch faulty, the unit will not work.
Sep 01, 2009 | Maytag Dryers
Dryer was making noise each time it rotated. Next
HI, seems to be a busted belt here. have it replace asap if possible.
Jun 22, 2009 | Magic Chef CYG4000AWW Gas Dryer
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Jan 13, 2009 | Dryers
Kenmore Series 70 80 90 PN281798 Dryer Motor Logo
14 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
