Question about Xerox ColorQube 8900X Solid Ink Multifunction Printer - Color - Plain
Getting error code 093-516
Jobs held for resources. Resources are correct. Error message 093-516
    Welcome Back:
    Visited the website for 2 consecutive days.
I looked at the Xerox 8900 support page: http://www.support.xerox.com/support/colorqube-8900/support/enus.html
The answer I found for Error Code 093-516 was problems with Yellow Ink Stick. Our printer had been switched of for quite some time which probably caused the ink stick/sticks to get stuck (or something). I opened the ink bay and pushed slightly on all the sticks to make sure they were "all the way in", added some more ink behind them and it started to work again.
I had to do a few cleaning jobs for smudges and now it's fully operational.
Posted on Dec 09, 2015
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    Resources allocation for scan faild
    Try to reinstall the printer driver.
    Nov 12, 2015 | Office Equipment & Supplies
    There is a paper jam
    The solution depends on which type of printer and which model it is. Generally, you must open the access door/compartment and try to get the paper out. I had a bad paper jam last week and I had to open the access door (same access area you use to change out the ink cartridges) and do a lot of pulling and maneuvering. Don't force the paper too much or you might break the printer.
    Mar 06, 2011 | Kodak Office Equipment & Supplies
    I keep receiving mail failure error messages form "my mailbox" that I did not send although the address is mine. What is happening and how may I stop this?
    Yahoo mail is related to networking telecommunications. First ascertain that the computer network structure is in place. For example, trace dial up telephone line network connections as least allowing media displays. Also recognizable with dial up internet connections is least displays considering the structure from which shared resources are attained. For example, dial up least has enough shared capacity to contain media especially with picture videos least displays also recognizable as error messages on computer. Alternately, computers that are networked with Ethernet as high capacity network structure has an enormous capacity to display media either picture graphic viderograpic or extensively. Wireless networks has an innovated capacities compared to Ethernet cable networks. In situations that computer resources are in place to support media display should least produce malfunctions discussable. First, the resources like with yahoo website experiencing malfunctions from host provider least displays on computer. Refer with the yahoo website experts with issues of malfunctions. Usually whenever, yahoo were experiencing malfunctions would be made available on network site by administrator of resources. Also, encountering conditions as member requires informing the appropriate entities responsible to rectify conditions to make functionality attainable as before. Improtant mail conditions with networked structures include creating spaces within mail boxes to allow resourcefulness. For example, yahoo mail boxes that attain huge volumes of resources least display appropriately either as slowness or malfunction messages requesting defragmentation. Also, in situations that the mail box has materials that are malicious to computer would leas display either that device recognizes malware or has already been infiltrated with virus program. Computers that have antivirus program scanners should be activated to rediscover the yahoo mail experience. Also, ascertain that the computer f feature of protective mechanisms is relaxed to capture resources from an area on the network internet. For example, computers that been set to antivirus protect would hamper the media displays from several location including the internet.
    Feb 27, 2011 | Yahoo Mail
    What is error code 16
    Code 16
    Windows could not identify all the resources this device uses. (Code 16)
    To specify additional resources for this device, click the Resources tab and fill in the missing settings. Check your hardware documentation to find out what settings to use.Solution button: None
    This code means that the device was not fully detected. When a device is not fully detected, all of its resources may not be recorded.
    To resolve this error code, click the Resources tab in Device Manager to manually enter the settings. Good luck..
    Apr 29, 2010 | VeriFone TRANZ 380 Transaction System (X2,...
    Xerox ColorQube 8900X Solid Ink Multifunction Printer - Color - Plain Logo
    1,324 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    CheckitRight
    CheckitRight
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
