Question about Kenmore 24852 Top Load Washer
Doesn't always agitate but runs through all other cycles
Kenmore model 22852. Never know when problem will appear, Can wash numerous loads without trouble, next load doesn't agitate.Have to play with the timer, spinning dial stopping at times to pull knob out and see if the agitator starts up. Eventually will get it to work in wash cycle, rinse fills fine then may or may not agitate. Timer continues to run, tub empties water and spins dry. Next load may run through cycles fine. It's driving me crazy.
  • johnpavelko May 26, 2009
    Sorry about this but I did leave out a major fact...I already replaced the timer and it still acted up so just for fun put the original back in and they both did the same thing. I now have  the new timer in the machine and the original on my work bench. Still have on again off again agitation (or should I say agrivation) when I run the machine.
    The machine is actually a Kenmore 80 series Model 110 22852 100 Type 111 but I only found the 24852 listed on the website when I was looking up kenmore machines if that makes any difference. I was wondering if the "Speed" selector could cause the problem? I have tried setting this switch to other settings (Delicate, normal, handwash or heavy duty) but that didn't seem to make a difference either. Mom (she's 84) just wants to buy a new machine but this one washes fine when it works and it seems in very good condition otherwise. Any other suggestions will be appreciated.
    Sincerely
    John
  • 6,784 Answers
HI. you can eliminate this issue be replacing the timer control device. this device is faulty and it should be replaced as soon a s possible. the dial you mentioned in your post, initiates all the actions that the washer will go through in the designated time chosen. if this timer control device is malfunctioning, it will interrupt the normal functions of the washer.
If you could give me your complete model number, i can direct you to a on line parts store where you can order this part on line for a great price.
Posted on May 22, 2009
  • Michael Masters
    Michael Masters May 26, 2009
    OK, check the lid switch. if this switch is faulty and if it has a short, it will affect the agitation and spin as well. check to see if its loose and check the wire that are connected to it as well. let me know if the lid switch is OK.
  • Michael Masters
    I would also inspect the entire wiring harness from the timer to the motor and all switches. this could be as simple as a faulty wiring harness.
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Spin cycle or agitate doesn't always engage. I
There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
I have a Kenmore 80 series model 22852 makes lound rattling sound
might have restriction in drain pump. clean out drain pump.
Jun 24, 2009 | Washing Machines
Kenmore Elite Top Load does not spin on spin cycle
Hi, If the inner tub has dropped down, you will need to change the block that holds the tub to the shaft. Remove the agitator cap and then use a 7/16" socket to remove the bolt holding the agitator in.
Lift the agitator out and look at the block holding the inner tub. There should be two slots with two tabs sticking up inside them. You will probably see metal shaving as well.
If this is what you see, please let me know and I can direct you on further repair.
Thanks
Vic
May 30, 2009 | Washing Machines
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Kenmore Model 110.26712693 stuck on agitator cycle
Your air pressure hose going to the water level switch is pinched.
Open the top control panel to access the clear plastic tube and relieve the pinched area.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Agitator not working 90 series model # 11026912691
Hello aksward,
Welcome to Fixya.
Here are some suggestions for any Kenmore washers
Let me know how it goes. I'm still thinking and searching my repair manuals!
Huuum
Please remember to leave a rating!
KENMORE ELITE TOP LOAD
Washer stops, won't fill, rinse or agitate
• Check the following:
Is the power cord plugged into a grounded 3 prong outlet?
Is the indicator on the Cycle Control knob properly lined up
with a cycle? Turn the Cycle Control knob to the right slightly
and pull to start.
Are the water inlet valve screens clogged?
Are both the hot and cold water faucets turned on?
Is the water inlet hose kinked?
• Does the water level seem too low, or does the washer
appear to not fill completely? The top of the agitator is
much higher than the highest water level. This is normal and
necessary for clothes to move freely.
• Has a fuse blown or is the circuit breaker open? If problem
continues, call an electrician.
• Are you using an extension cord? Do not use an extension
cord.
• Is the washer in a normal pause in the cycle? The washer
pauses for about 2 minutes during certain cycles. Allow the
cycle to continue. Some cycles feature periods of agitation
and soak.
• Is the washer overloaded? Wash smaller loads.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
Oct 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore elite front loading machine
Even replacing pump is not always the answer,in fact most of the pumps are replaced when they are just clogged.Dont waist any more money.Did the servicer check inside the hoses.In the drain cycle can you here a pump running>?
Jun 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 24852 Top Load Washer Logo
65 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
