Question about Miele CVA 4066 Stainless Steel
The expresso of my miele cva 4066 coffee machine does not come out hot, just luke warm while the cappucino is hot because the milk comes out hot enough. we have the temperature at a max on the expresso. why the difference and what could cause this problem
  • mpservices Jan 04, 2014
    Is this only on expresso? is the coffee or hot water hot?
SOURCE: My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Posted on Mar 15, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: Our Miele CVA 4066 coffee
Hello
Check that you have water available from your water line to the coffe maker,Also you may need to manually fill the tank first time around.
Here is a link for the manual check out pg 56.This is a pdf file.
http://mieleusa.com/manuals_pdf/Residential/Coffee_System/CVA4066_us.pdf
Posted on Jan 08, 2011
  • 128 Answers
SOURCE: I have a three month old Miele CVA 4066. I have
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Posted on Feb 24, 2011
mc1bean
  • 3053 Answers
SOURCE: Miele CVA 615 coffee machine. Makes several
Hello, dan
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 29, 2011
  • 40 Answers
SOURCE: Not enough water comes out when making coffee on
Your nozzles could be clogged or the percolator itself is clogged. Try to stick a toothpick into the nozzles to clear up any blockages, then perform a descale on the system using 2 large tablets. Make sure the tablets dissolve completely, if not you risk the chance of clogging the whole system.
Posted on Feb 08, 2012
Expresso is too large
Nancy, this setting is controlled by the settings menu. You reach that by right arrowing through the different beverages/menu selections until you select "Settings".
  • In settings, scroll to "program the amount"
  • place a cup under the spout
  • select the beverage you want to program, espresso in this case
  • select start
  • select okay when the amount of water has been used
  • the machine will remember this setting for future espressos
  • the same menu structure allows you to control the amount of coffee ground, as well as the amounts for other beverages
Mar 15, 2016 | Miele CVA 4066 Stainless Steel
Miele CVA5065 coffee machine- the manual states : "fill the big plastic container to the max level". What is the volume to the max level?
Filling The Water And Coffee Bean Containers - Miele CVA ...
www.manualslib.com > ... > Coffee Maker > PW 5065 > User manual
Miele CVA 5065 Manual Online: Filling The Water And Coffee Bean Containers. Thecoffee machine must be cleaned thoroughly (see ''Cleaning and care'') before you... ...up to the "Max." mark. A valve at the front of the water. container will ...
[PDF]Operating and installation instructions Built-in coffee ...
Nov 25, 2015 | Miele Coffee Makers & Espresso Machines
Coffee makers Miele cva 4066 stuck on fit jets in central spout
You might need to reset the coffee maker by turning it off and then turn it on again.
Apr 28, 2015 | Miele Coffee Makers & Espresso Machines
Miele 4066 coffee says "fill the milk flask" when its full. How do I replace the sensor? Where do I buy a sensor from?
I have found that most of the time that I see this fault there is a broken wire at the brass contact that the lid of the milk container contacts with. This contact is on the door of the machine on the edge of the oval hole that the milk flask is inserted into. There is a torx 10 screw holding the cover on - remove that screw and you can lift that cover off. You will see a single wire going to the contact. If this wire is in fact making a good connection, then the issue is in the top handle of the milk flask - possibly water inside. I hope that helps.
Jan 10, 2015 | Miele CVA 4066 Stainless Steel
Milk and milkfroth clogs up after about 4 to 5 cups
It can be several things .. but the first to check is that the milk pipework is not clogged and also that it is fully cleared of milk residue. In other words it may be partially blocked. You need to buy some 'milk line cleaner' ... Miele make it but there are after market products that are cheaper. I use the Cafetto product called 'Pulatte' and it works well but others will do. You need this product for general maintenance anyway. If this does not solve problem then you need to provide specific details on the precise nature of problem.
Aug 16, 2013 | Miele CVA 4066 Stainless Steel
Miele CVA 4066 stopped frothing milk
It sounds like the venturi tube is blocked. Have you ever removed the frothing unit and cleaned in manually? I have a model 4085 and I can reach under where the milk exit tube comes out, twist anti-clockwise (if you are looking up at it) and the whole assembly with the inlet and outlet tube comes out. These pieces can then be individually taken apart and rinsed thoroughly with warm water. If you put it back together (don't forget to twist the connector that locks it back in) and the milk still doesn't froth, take it out again and use a small needle to clear the top of the clear venturi tube which sucks air in to do the frothing. If it is really badly gunged up it might need to be replaced, but mine is 5 years old and still going with regular rinsing. My whole brew unit had to be replaced after 4 years at a cost of about GBP 200, but that's another story.
Nov 21, 2012 | Miele Coffee Makers & Espresso Machines
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
I have a three month old Miele CVA 4066. I have recently cleaned the unit twice (using little tablets in coffee grinder), as well as descled. The coffee, expresso, etc. is barely dripping out of the unit. ...
Feb 10, 2011 | Miele CVA 4066 Stainless Steel
Steamed milk
I've just taken delivery of an S9 and my lattes were lukewarm too. What you have to do is move the dial on the steamer to the 3 o clock position. See http://cdn2.libsyn.com/coffeegeek/jura_frothxpress.mov?nvb=20081110133816&nva=20081111133816&t=018ee7ad85c33f422c6a5 . Latte I just made was piping hot. If that doesn't fix it, try the Products settings. If still lukewarm I think you should contact your dealer, maybe you have a duff machine.
Oct 18, 2008 | Jura Capresso Impressa X90 Espresso...
Miele CVA 4066 Stainless Steel Logo
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Colin Stickland
Colin Stickland
steve morris
steve morris
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
