Question about Rio Carbon MP3 Player
Door not fitting snug in frame anymore
Passenger door does not sit snug in frame of car it appears to have worked loose somewhere. I can fit my finger between frame and rubber seal at top of car door when windy it blows rain in a little. What is going on?
Car door alignment
if you place your knee on the inside of door and pull with both hands on the top of door frame with window down until it fits snugly in its opening youll fix your air leak
Oct 04, 2013 | Chevrolet Tahoe Cars & Trucks
How do yoiu get the door hindges off of a 89 chevy 1500
To get the door off you have to take out the door pins. The top pin goes in upwards and the bottom pin downward. Make sure you put a jack under the door frame to ease pressure on the pins. Tap pins lightly to remove them. Just like a house door. You will need new bushings. If you find that the bushings are not fitting snug to the hinge, loose, you may need to drill the hole out a bit bigger, and use an over sized pin and bushing to replace it. Good luck, I hope this helps, please rate this solution
Jan 11, 2013 | 1989 Chevrolet C1500
Rubber boot and spring need put back in
The rubber boot presses on the rim, and the spring clamp fits in the groove behind it. Don't overtighten.
--W/D--
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer metal band on gray seal
The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you have questions, please let me know. I hope this helps you.
Jun 30, 2009 | Washing Machines
My kenmore he2 plus washer door gasket is loose.
it goes on the groove in the gasket at the door , the side view of the gasket would be a V, it goes right in the middle. make sure the gasket is first snug on the metal frame groove. the spring is very tight, start at top then work down, use a flat screwdriver to pry it in at bottom. it may help to wet the gasket
Apr 27, 2009 | Kenmore HE2 Plus Front Load Washer
Cannot open door from inside on front driverside
29 cent part my fix your problem. There is a nipple on the interior door lock lever that fits into a slot on the door handle lever. Look at passenger side to compare. The nipple is covered with a plastic spacer that may come off. The spacer keeps the lock nipple snug in the handle lever slot; pull the handle lever, it engages the lock lever, opening door. I bought a .29 cent aluminum spacer (#8x1/4 x 1/4) from Orchard hardware. Take needle nose pliers and slip the spacer on, then super glue. Unfortunately if lock lever (where riveted) is badly worn, then it may pivot upward instead of perpendicular to the door, thus defeating new spacer. But you may now be able to open door by pulling handle lever and lock lever at the same time. If you need to replace door handle, others on this site have suggested that you not replace metal frame that door handle is mounted on, but drill out rivets that hold door handle mount.
Jan 29, 2009 | 2001 Lincoln LS
DISH WASHER, STILL HAS A LEAK FROM THE DOOR.
Once the gasket is in place, check it for fit against the door frame. It should fit tightly with no cracks or bulges between the gasket and the frame. If necessary, tighten or loosen the retaining screws, or refit the gasket in the clips or the door channel. Then run the machine through a washing sequence and check for leaks.
If you spot a leak, and the gasket seems to be properly in place, try adjusting the door latch. The trick is to position the gasket against the frame of the door without flattening the gasket or squeezing it too flat when the door is latched properly. Adjust the latch or the gasket until it fits snugly against the door frame.
Servicing the Door Latch
The latch on a dishwasher door is opened and closed repeatedly, and this hard use can lead to mechanical problems. The latch may be loose, or it may have slipped out of position, throwing the alignment off and preventing the door from closing properly. When this happens, the latch does not engage properly, and the dishwasher will not start.
In many cases, you may be able to solve the problem by adjusting the position of the latch. Move the latch slightly by loosening the screws that hold it. Slide the latch with your fingers or pliers; the screw slots are made especially for this purpose. Close and open the door to see whether the latch is properly aligned. Tighten the screws to hold it in the correct position.
After repositioning the latch, check to see if it's working properly. Close and latch the door and turn the control knob to the ON position. If the dishwasher doesn't start, the latch is faulty. Replace it with a new latch, connecting it the same way the old one was connected. You may have to move the new latch back and forth several times before it works properly.
PLEASE mark this answer as a fixya! thanks
Dec 26, 2008 | Samsung Digimax A503 Digital Camera
MAYTAG JETCLEAN QUIET PACK
hi Replacing the Door Gasket
If water leaks through the dishwasher door, the gasket is probably faulty. Open the door and examine the gasket. It should be soft and resilient. If it's worn, cracked, or hard, it should be replaced.
Oct 10, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Adjusting the oven door hindges for a snug fit
i wanna circuit board of inkjet printer and faluts finding
Dec 19, 2007 | Frigidare FGB24S5DC Gas Single Oven
Rio Carbon MP3 Player Logo
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
