Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Installing 2harddisk pimary/slave pin connection
Can i ask how to connect the primary/slave pin when installing 2hdd in one pc, do you have any link to provide, thanks
    President:
  • 1,865 Answers
The jumper configuration is listed on each harddrive. You have to make one the master, and the other the slave
Posted on May 22, 2009
WD1001fals as slave
SATA Hard Disk as a Slave b> An SATA hard drive is an internal hard drive that connects to your computer's motherboard. It is even possible to connect multiple drives to the same computer; however, only one drive can be the master hard drive; the other(s) must be slave drives. This is because the master drive has the operating system installed and must be used to boot up the system. When installing a new SATA hard drive onto your computer, you must set it as a slave.
Power down your computer and disconnect the cables. Remove the Phillips screws from the exterior of the computer case and slide the case open to expose the interior of your computer. Identify the hard drive at the front of your computer, then slide the new SATA drive in underneath. Insert the smaller power cable into the power port on the side of the SATA hard drive. Follow the power cable running out of the current hard drive and insert it next to it on the motherboard. Pull out the ribbon cable, which has three different connection ports: one on each end of the cable and one in the middle. The connection port on the middle inserts into the slave drive and is slightly different than the other two ends (the pins built into the port are in different locations than the other ends). Insert the middle connection port into the ribbon port on the back end of the SATA hard drive. Plug one of the opposite ends of the cable (doesn't matter which one) into the SATA connection port on the motherboard (your current hard drive is inserted here). Once connected, this completes your slave drive connection. Second SATA 2 Hard Drive as a Slave b> Installing a second hard drive in your desktop PC or notebook is an option used to increase hard disk space without losing or transferring the data from your original hard drive. Using this method not only increases hard disk space, it also increases the virtual memory space for the Windows operating system, increasing operational efficiency. One of the ways in which a BIOS can recognize the second hard drive is to boot it as a slave drive, with the primary hard drive booted as a master drive.
Turn the PC off and remove the desktop chassis. Refer to the pin connector diagram. This is displayed on the sticker, on top of the hard drive, for the position of the slave pin. Place the plastic connector on the slave pin as detailed on the diagram. Connect the hard drive to the power and IDE/SATA cable. Ensure the other ends are connected to the motherboard. Use the screws to mount the drive. Replace the desktop chassis. Turn on the PC. Enter the BIOS, by default this can be done by pressing F2. If this does not work consult your motherboard manual. In the BIOS, press right until the boot device tab is highlighted. Set the slave drive to boot following the primary drive. Read the bottom line and use the relevant key to save the settings. Restart the PC.
Hope it helps.
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/ Installing a hard drive.
Jan 24, 2013 | Western Digital WD Caviar Black WD1001FALS...
Primary slave drive fails
Go into the BIOS and make sure you are trying to boot from the Primary Master Drive first. If not, move the Master Drive to the 1st boot position.
If the above fails, you could just remove the power cord, remove the case and notice how the two drives are connected and remember it. There will be one cable that provides power to the drive from the power supply on each drive. Also, there might be one cable that connects both drive, or there might be one in each drive, etc. I would disconnect the power and cable on one of the drives and try rebooting. If it fails and you have one cable that connects both drives, try the other cable connection and reboot. If it still fails, then I would try doing the same thing with the other drive.
If all the above fails and your system has the IDE (whereas the cable has about a 2 inch end with about 20 holes that plug into the 20 pins on the hard drive) interface, remove the drive to check and see if the little pin on there along is set to Primary, Master or Cable Select. Normally on a two drive system they will be set to CS for Cable Select and the IDE Cable based on how it is plugged into the drives determines which is Master and Slave, but older systems might have the Master and Slave setup.
Apr 09, 2012 | Sony VAIO Digital Studio PCV-RS410 PC...
How change prymari device?
You can either look into this online manual or follow the instructions given below.
http://support.dell.com/support/edocs/systems/dim4700/en/om/Y69490LRs.pdf
In the case of loading a particular Operating System(OS) from a specific Hard Disk, you can change the boot priority from BIOS (Hope you know to get into BIOS) as shown in the picture
Or if you want to change the physical configuration of your Hard Disks to Master and Slave, then follow these steps.
  1. Open up the side panel of your PC Case.
  2. Disconnect all the wires from both Hard disks.
  3. Look over the labelled top part of each hard disk to know the settings of JUMPER PIN so as to set it as primary(master) or secondary(slave). Please note that if you are using IDE hard disk, this may be enough. But in the case of SATA, inspite of this, you may also require to install RAID Driver after connecting them back into the computer. These drivers can be downloaded from http://www.dell.com/support/drivers/us/en/19/DriversHome/NeedProductSelection (You may require to set up your product manually and download Serial ATA drivers)
  4. (Connect them back, Screw up- if you haven't done it already). Now you may be able to use the required hard disks as primary(master) and secondary(slave).
You can also watch two videos of changing jumper of the hard disk. But be careful while replacing jumper. Any incorrect configuration or jumper setting or damage of pin may cause in device failure or result in damage of your hard disks.If you have any further doubts, feel free to ask me...
Jan 07, 2012 | Dell Dimension 4700 PC Desktop
How to install 2 t hard drive in computer compaq
A 2Tb hard disk will be a SATA hard drive. If your PC Desktop does not have a SATA disk controller then your have a couple of options.
1. Insert a SATA controller card into the PCI expansion slot, mount the SATA hard drive inside the PC case and then connect the SATA hard drive to the controller (you will also need a 4 pin power to SATA adapter cable) and install the SATA controller driver.
2. The other option (and the easiest) is to purchase an external USB 2Tb hard drive. All you need to do is, plug it into the USB port of your computer and it will see it as an external storage device.
Oct 22, 2010 | Computers & Internet
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
Pin connection for 'master ..slave
I assume these are IDE drives since SATA doesn't require jumper settings. . .You will need to set the primary drive jumper to master[ma] & the secondary drive jumper to slave[sl]. Some systems require dual hdd systems to have both set to the cable select[cs] jumper. Check your motherboard or system manufacturer manual to see which setup your system requires. If you lost the manual most manufacturers have it availablr on their website under the support link. Hope this helps.
May 23, 2009 | Excelstor Technology J880 Hard Drive
Instalation of ad on IDE/SATA PCI card
You have to set one of the DVD as Master end the other as Slave if they share the same ribbon connector. Do this simple test: let only one of the DVD connected. If the PC "sees" this one, then the card is OK. If need more instructions, just post a comment.
Apr 16, 2009 | Computers & Internet
Hard Drive Installation
Hi emceedrive, I gather you are using ATA/PATA IDE hard disk drives? Each hard disk drive has a large white sticker on it. Listed there are pin settings to set the IDE to Master or slave & Master with a slave. (We want to leave you're drive with windows on it alone). Not changing its jumper or not adding a jumper for now. We are not hooking up you're second drive just yet either.
Oh, please you're not an idiot either.
Unplug the power cable from the PC & open you're case.
Please open you're ASUS P4P800 SE manual to section 2.2.3 Motherboard layout. We want to connect the data cable to SEC_IDE1 first because once PRI_IDE1 is connected you will not be able to connect SEC_IDE1's data cable up to the DVD drive bay.
So grab a data cable for you DVD drive. It may have three connectors on it. Plug the connector that is the furthest from the other 2 connectors on the cable into the motherboard slot named SEC_IDE2. The data cable only goes in one way. Run the remainder of the cable up to the DVD player but do not connect it to the player yet. It is ok to fold the data cable which will help in routing it upwards to the DVD bay. Than connect the data cable to you're primary master IDE drive. (The one with windows already installed on it). The data cable should look just like the DVD data cable. Again you want to connect the furthest connector on the data cable into the MB slot named PRI_IDE1.
For now it’s best not to install the drive into the drive bay. Stand it up next to your case or lay it down flat with a sheet of paper under it. Connect the power cable to the drive. Plug in the PC's power cord & power up the PC & start pressing the delete key every two seconds until the bios main menu loads. You should see the Primary Hard disk drive listed at the main menu. Now go to the title Boot in the bios. Open boot order. The boot order of the devices should be as follows.
Boot device 1. (Floppy Disk Drive)
Boot device 2. (DVD Disk Drive) [None shown it’s not connected to the system].
Boot device 3. (Model number of your Primary IDE Master HDD).
Once this is set, save the bios & exit. The system should auto restart & windows should load. Let windows finish loading. Than shut down windows normally.
Unplug the PC's power cord. Since you had to remove a DVD drive you'll need to set the remaining DVD player's jumper on the drive to a Master & connect the data cable & power cord to it. (You may have to remove the DVD to see where the Master pins are located. It will be marked on the DVD player near the pins).
Now take you're new drive, do not insert it into the drive bay. Look at you're Master drive's white label. Set the jumper on the master drive first. It should be set as a Master drive with a slave.
Connect a jumper for this.
Go to you're new drive. Again look at its white label. Set this drive's jumper as a Slave drive. The Master drive should be connected to the end of the data cable. The new slave drive should be connected to the next in line connector.
Once all data cables & power cables are connected plug in the PC's power cord & boot the system, again pressing the delete key every two seconds until the boot main menu loads. Now you should see the Primary IDE Master drive & you're new Primary IDE Slave drive listed. You should also see the DVD as the Secondary IDE Master. Go to the title "Boot" again. Set the boot order as mentioned above. Save & exit the bios. Windows should load as it did before. Once windows has finished loading open windows Explorer & see if you're new slave drive is listed.
Shut down the system & unplug the power cord. Unplug the slave drive & mount it into its drive bay. Take a black marker & mark the side of the drive as slave. Disconnect the Master drive & connect it into its drive bay. Reconnect the data cables & power cables. Check all connectors before closing the case up. Re-connect the PC's power cord & boot the system. Everything should be fine. If you have a problem getting the data cable connected to the slave drive because its closer to the DVD drive as opposed to the Primary IDE Master drive you can make the slave drive a Secondary IDE Master (Change its jumper setting according to the drive’s label for Master with a slave) & connect the DVD player as a Secondary IDE Slave. (Change its jumper to slave). Change the Primary IDE Master drive’s jumper as a Master with no slave, single drive. That all.
Good luck emceedrive!
Take your time. Any troubles please post here.
You should be fine though.
Mike
Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Dell Dimension 5000 Desktop
You don't need drivers for a hard drive! Just plug it in and it will be recognised by the BIOS.
The only thing you will need to do is make sure you designate it as a primary or slave drive - whatever the old drive was set to. On the back there is what looks like an eight pin plug, with a jumper across two of the pins. Depending which pins are connected will change the drive designation. There is usually a sticker next to them telling you which to connect for primary and slave.
Matt
Mar 21, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Hard drive..
Using SATA, there is no Primary/Secondary Master/Slave connection. Each HDD is connected to One port straight. As for partitioning, you can either use Fdisk or you can boot straight from the Windows CD and create Partitions and load Windows.
Sep 11, 2007 | Microsoft Windows XP Professional With...
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
56 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
