Question about Beko Dishwashers
Bbeko dw601 no programmes will start!
The dishwasher buttons have stopped working. There is definitely power to it and it was working fine yesterday! There are two programme lights lit at the same time (should only be one) and neither the programme select button, start button, or half load button are doing anything. I have tried turning the machine off at the power supply and leaving it for half and hour to reset it but it still has the same problem. Please help!
4 Suggested Answers
  • 159 Answers
SOURCE: Machine won't activate
well I never heard of that brand so because you said a new flat Im guessing your form England. Good luck with the move. Ok I belive your problem is possibly the main control bord is bad.what you describe sounds like it. the only way to rest it it would be to replace the bord. doing that it should function normally. Good luck.
Posted on Aug 22, 2007
  • 7 Answers
SOURCE: problem selecting programme
hi
sounds like you have a heater problem,check connections on your main module behind control panel if all appear ok check you heater for open curcuit.
Posted on May 18, 2008
rickead1
  • 1998 Answers
SOURCE: On my whirlpool ADP962 dishwasher
check the thermal cutoff located inside the door for continuity and check the heater to assure this is working as well you can also do continutity test on the heater if the heater is not functioning properly then unit will go no further into washing the same with the thermal cutoff if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
Posted on Apr 26, 2011
Will not run? Doing laundry yesterday an it stopped in middle of cycle. Now when I push start button it clicks but will not start. The lights all work so it has power. What is wrong?
turn the breaker off which should be in your furnace room.
Wait a few minutes and turn it back on. It will reset the computer in your machine and it should work just fine then. This also works on dishwashers.
Jul 08, 2015 | Dryers
How to fix my Indiset d41 dishwasher ? The power button trips out the electrics ! Stopped mid programme , wont drain , still water left in it after it flooded the kitchen . Cant try any other programme as...
You have a component down to earth. The problem isn't the start button. Most likely to be the element, but ciuld be wash or drain pump. Check the element with a resistance meter first, when you find the componant at fault, replace it
Feb 04, 2018 | Indesit 18 in. D41 Slim-Line Free-standing...
I have a Miele G641 dishwasher and it wont drain and it is coming up with red lights saying inlet/outlet, salt intake
One thing these guys did not point out is to turn the knob to STOP before starting this procedure (otherwise you will be ignored) Once done this works fine.
-- from the manual ----------------
Before rectifying the problem you must:
- Turn the programme selector to the "Stop" position.
- Switch the dishwasher off using the "On/Off" button.
Nov 15, 2009 | Miele 24 in. Novotronic G641 Plus Built-In...
Stops part way through programme water still in machine. Now no power to machine. Problem happened yesterday - cleaned filter and pump - power came back. Programme started but then stopped. No power -...
Either there is a bad capacitor in the control panel, or the power supply has a faulty capacitor. You will have to get a multi-tester and test each component for resistance and current
Jul 05, 2009 | Dishwashers
No Power
You probably have a bad door switch assm, there is no reset on this unit, if you have a bad door switch the unit thinks the door is open so it won't start.
Jul 15, 2008 | Whirlpool 24 in. DU900PCD Built-in...
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
Dishwasher stopped mid programme
First place I would go is the door switches, make sure the dor switch assembly is not broken, and switches working.
Jan 05, 2008 | Dishwashers
Kitchenaid 24" SS dishwasher
the first thing to check is power. check your breakers to see if any are tripped. if so turn it off than on some breakers do not reset if you just switch them to the on position. also check if it has a plug or shut off switch in a cabinet nearby .
Dec 31, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Apr 08, 2007 | Kenmore 17342 / 17349 Built-in Dishwasher
Dishwashers Logo
74 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
