Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears / craftsman (1995) wall mount switched just quit working.
I just bought this house and the switched worked for a week then quit working. I noticed the remote has a lock button on it and wonder if it some how got pushed. The remotes work fine so I'm not sure what I did wrong. I also bought a wireless key pad that you mount outside that I can not get to program. Any suggestions? the remotes are 9 pin and the remote states its from canida.
  • goff_erin May 11, 2010
    The opener I bought says it will work with all brands including mine. It is Chamberlain Clicker Universal Keyless Entry Model KLIK2U. My garage is a 1995 Craftsman liftmaster (canadian) with 9 pin remotes. I've followed the progaming instructions and have had no luck.
  • gliptone May 11, 2010
    are you sure the wireless unit is compatible with yours
    President:
  • 3,197 Answers
The wireless keypad will not work with your opener.
Posted on May 22, 2009
I have a wall mounted Craftsman Premium Control Console with a motion detection sensor to turn the door opener light on when I enter the garage. Will it work with a new Sears Garage Door Opener?
Look at the manual that came with your new opener. If there is a wire that is denoted "garage opener light" then yes it should work. Craftsman Control Console Premium
The description says for Sears Garage Openers since 1995.
Mar 12, 2018 | Building Materials
My craftsman 132B2171-2 wall mounted panel is not working
Either the wall control itself has quit or the wiring to it is bad. You can remove the control from the wall and remove the two wires. Momentarily short them together and if the operator works you know the wall control is bad.
Sep 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
I bought a house with an old (1980's) Sears garage door opener. I have two Stanley remotes that were in the house at the time of purchase. The opener works fine at the hardwired button in the garage but I...
On the remotes put switch #1 in either position and match up switches 2 through 10 to the dipswitches on the motor unit. There is a good possibility your receiver has quit working.
Mar 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remotes suddlenly quit working and the wall switch
sounds like you had a power spike
need to check code to see if its the same as what is on the remote
should be 5 numbers on the opener
where your wires hook up see the numbers and see if they are the same as what is on your remote
Feb 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Brand new sears GDO 3/4 hp DC motor with backup battery. One day all remotes work, external keypad, and homelink. Next day, ignores them all (!!??) have re-checked wiring, safety and wall switch. I get the...
The 3 flash error code is "Door control or wire shorted". Try disconnecting the wall control for a time and see if your problem quits. If you used staples on the wiring make sure they did not cut the insulation.
Jan 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Genie Screwdriver, garage remotes won't work, batteries are fine.
Your receiver has quit working. A call to your local Genie dealer should get you back in business.
Sep 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote to garage door opener wont work no solution on fixya
The Clicker is a hard one to program. You might try it a couple more times to be sure it won't work.
The 61LM is the Liftmaster remote that goes with that unit. There is a possiblity that the reciever on the board is bad. That board is no longer available but you can get a 635LM external reciever that is backward compatable with the 61LM remote.
Jan 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door Premium Control Console Failure in Cold Weather
first guy has the mounting screws tp tight or the wire is preventing wall station for sitting flush against wall....second guy check your safety eyes...
Jan 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
203 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
