Question about HP Office Equipment & Supplies
How to install cartridges
I have a M1210 laser printer and after removing the cartridge I can't put it back.
  • syed jabir ali
    syed jabir ali Jan 03, 2014
    Hi richardjconn, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    At the back of the printer above the barcode you'd find a Product Number, may i have it please.?
  • HP Master
  • 1,511 Answers
I assume you did get the EXACT replacement cart for your printer, correct? If not you will never get it to work. If you did get the exact duplicate, it came with a set of instructions for installation in the package. You can't get better help installing a cart. than what comes with the item purchased.
Posted on Jan 03, 2014
  • 36 Answers
SOURCE: Printer Not Registering New Cartridge
try installing the original cartridges u got with the printer & reseating the power cable assembly....make sure u hav removed the tape frm the cartridge....
Posted on Jul 12, 2008
SOURCE: cartridge problem
dell suckxxxxssssssssssss
Posted on Sep 28, 2008
SOURCE: Error Light on Brother HL-2170W
Do not try to depress the green lever, since you need to remove the cartridge AND its base altogether. Just grab the front middle part of the assembly, pull it out slowly and steadily. You may need to apply extra force in doing so as it does take some effort to disengage the cartridge assemly from its seated position.
After the cartridge is removed, you may find some jamed paper inside. simply remove it and the printer should work again.
You may email me at stevenjoy@gmail.com should you have further questions.
Posted on May 21, 2009
SOURCE: fuser paper jam on Dell mono laser mfp 1125
Please double check if all doors --- including the paper tray cover --- are firmly (repeat FIRMLY !) closed --- seemingly all such are designed as precautionary measures for safety operations.
Posted on May 31, 2009
  • 20 Answers
SOURCE: New cartridge installed printer gives message that
Check both cartridges, one might still have plastic film that needs removal.
Posted on Dec 17, 2009
My printer asks me 10.94.00 remove shipping locks for printer laser jet p4015n
This error occurs if you forget to remove both the shipping tape and the locks from the cartridge. Remove the cartridge from the printer and look for orange tabs. There should be three of them. If they have been removed then you may have a bad cartridge, try installing a different cartridge, if second cartridge fails then likely it is a problem with the printer.
May 22, 2015 | Laser Office Equipment & Supplies
Printers Led Screen apear i.e. "Toner not instaled"
remove and reinstall the cartridge.
Check the switch on the top( Whether smooth operation or stuck) if it stuck then apply little
lubricant .
Jul 23, 2011 | Samsung ML 1610 Laser Printer
How do I load ink and toner in hp laserjet 1100
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.-------------- Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
Mar 25, 2011 | HP LaserJet 1100 Printer
How do i put new ink paks in hp
As this is a laser printer, the only supplies you need to install are the toner cartridges. These are a one piece unit with drum and toner all contained together. Open the fron of the machine and pull out the color that needs to be changed. Open the new box, gently rock the new cartridge front to back to ensure toner will print evenly. Remove the orange shipping locks being carefull not to touch the green drum. Insert new cartridge into printer and you are done. Printer should automatically perform a calibration after you close the front door.
Mar 21, 2011 | HP PRINTERCLJ CP4525N CC493A Laser
What do you do if the toner light comes on after you have installed a new toner cartridge
Did you remove the toner protect strip to allow the new cartridge to expose the toner?
Remove the Toner cartridge and reseat it. After reseating it, wait for the printer to recognize the cartridge, then turn the printer off, then back on.
Oct 12, 2010 | Brother HL 2140 Laser Printer
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
T640 printer put toner in the error message states please insert
Please remove the cartridge and then re-install it to make sure it is seated properly. Then close the front cover door and make sure it latches completely. Now turn the printer back on.
Mar 31, 2009 | Lexmark T640n Laser Printer
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Disconnected printer
If the lights are solid -
The error is caused by a defective cartridge, an unsupported cartridge, an invalid refill, or a cartridge meant to be used in another geographic region.
• If the print cartridge is not installed, install it.
• If the print cartridge is installed, remove it and install a new print cartridge.
If the lights are flashing
This means the photoconducter kit needs replacing
Sep 07, 2008 | Lexmark E240 Laser Printer
Cru fuser error
I already solved the cru fuser error by replacing the fuse of the toner cartridge.Thanks anyway for this information.
Jun 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
29 people viewed this question
Seeker5211
Seeker5211
