Question about Samsung Digimax S500 Digital Camera
TROUBLE SHOOTING WHEN THE POWER BUTTON IS PRESS A BEEPING SOUND IS HEARD AND THE CAMERA IS NOT COMING ON
  • 3 more comments
  • Anonymous Nov 04, 2007
    how do u fix it???
  • mayrah Nov 09, 2007
    when i turn the camero one bits 3 times and it shuts down, the lens is out all the time and does not close
  • Anonymous Nov 12, 2007
    same problem the lens is out all the time camera turns off and on by itself...how do you fix this problem??
  • Anonymous Nov 16, 2007
    yup! mine too! except it won't even come on. I've tried changing the batteries but nothing happens. the lens is out and everything.
  • Anonymous Mar 22, 2014
    camera then comes up with camera error
We had the same problem. It would beep three times then shut off.
The lens was stuck in the out position. My son played with it until it loosened up and it works now. It had nothing to do with batteries.
If yours is stuck out. twist and push until it goes back in.
Good luck
Posted on Dec 04, 2007
Computer does not start...long beeps heard from the unit
removethe RAM strip then insert it again or change the slot
Aug 25, 2014 | Computers & Internet
Dle2701v beeping flashing lights
It may be solve problem or maybe your dryer have some problem with motor also
The best method is to do your home work and you must do total trouble shooting procedure and replace defective parts if necessary .
Best way is visual check and check for any faulty component and parts and check all thermostats and sensors and look for clogged vent or any damaged or rusty or cracked components and use step by step deduction method for trouble shooting
Dec 07, 2013 | LG Dryers
Kenmore Elite washer service code CLL SrU
Re: Kenmore Elite 417; error CLL SRV We have well water and I think my error message and locked door were because the machine was trying to plump water and not getting any. I heard the error beeping and sent to check it out. There was another noise that didn't stop even after unplugging the washer, although the beeping did, which finally stopped after I turned off the water valves. Press and Hold the power button down to unlock the door and retry. If you still have trouble, call for service.
Sep 25, 2012 | Washing Machines
I have a brand new nikon coolpix s3000. it's on full-time auto focus. Any ideas?
You can change this in the menu while in shooting mode. This is from page 48 of the manual:
Choose how the camera focuses.
A (auto) M d (Shooting menu) M I Autofocus mode
A Single AF (default setting)
The camera focuses when the shutter-release button is pressed halfway.
B Full-time AF
The camera focuses continuously until the shutter-release button is pressed down
halfway. Use with moving subjects. The sound of lens drive movement will be heard
while the camera focuses.
Sep 28, 2010 | Nikon Coolpix S3000 Digital Camera
Ive bought the camera M530 yesterday and it makes a ticking sound when switched on as if it is something to do with the smart capture. Should I be worried that something is wrong with the camera or is just...
Just purchased the M530 for my daughter for her Bday. Noticed the same soft ticking sound when the camera is turned on. And yes, I agree with other posts that this is annoying. The noise is probably coming from the fact that the camera is set to Continuous AF (auto-focus) mode. Here's the solution: STEP 1 - Press menu button (should take you to Capture screen). STEP 2 - Using the down-arrow button to scroll down to AF Control (Still). STEP 3 - Using the right-arrow button select Single AF. STEP 4 - Press OK button. Another screen will come up with the radio button selected on Single AF. Ticking sound should be gone by this point. STEP 5 - Press Mode button. STEP 6 - Select shooting mode (Smart Capture, Video, etc.) and Press OK button. Good Luck.
Jul 30, 2010 | Kodak EasyShare M530 Digital Camera
Hi, my remote control mute and power button do not function. Is there a trouble shooting solution, or do i need to buy another remote? I own a Viewsonic N2752w 27'' widescreen LCD TV
Yes , point it at your digital camera or video camera and
in the viewer you should see the remote blinking a blush white
light when you press any button . sound like the pads are
dirty ,and need to be opened and cleaned.
Jun 16, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
My Polaroid camera i631 won't turn on!!
Here is the solution for your problem. If you look at your camera at an angle, you will see the zoom lens is little bent to the side. I want you to put press on it to snap-it into it's place. After you heard a click, then turn-on your camera. This will fix your cam.
Vicent
Apr 04, 2009 | Polaroid i631 Digital Camera
I have a Kenwood KVT-911DVD in my tahoe. I heard a pop coming from the back of my truck, i have an amp under my back sit. i thought i blew my amp, as luck has it, my transmission went a couple of days...
Do any of the lights on it come on. Have you tried to take it out and connect the red and yellow wire to the battery and the black to the truck frame? This to see of any of the lights come on. Did you try to press the reset button? If you press the button and nothing happens then you may have to send it back to Kenwood for them to reset it.
May 20, 2008 | Kenwood Car Audio & Video
Orion STV2551 27"TV...
The flyback transformer, and some other components may have failed. The main power supply may also be damaged.
It is impossible to know the exact failed parts without trouble shooting the set.
Jerry G.
Apr 14, 2008 | Orion STV2763 27" TV
Poor picture quality
I heard of problems with the focus on this model when in landscape mode. It's being related to a firmware problem. Are you shooting in landscape mode perhaps? In any case, this model is not very famous for taking sharp pictures, ans as far as I know got discontinued pretty fast. Kodak also won't repair it, just offer you a replacement. I also heard that the camera gets focus problems from opening up while in the case - a design flaw makes the power button easy to press while its closed in a case, after a while it damages the lens. This is the only problem that I heard Kodak are willing to fix out of warranty, if you press them hard enough. Hope you find a solution, good luck ;]
Jun 05, 2006 | Kodak EasyShare LS443 Digital Camera
Samsung Digimax S500 Digital Camera Logo
112 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
