Question about Jenn-Air 30" Smooth Top With Dual Element & Warming Center Jec9530bdb
Jenn Air JEC9530BDB Cooktop cooling fan no longer working.
Is there a way to determine if the culprit is the fan itself or the thermostat?
ranger25
  • 72 Answers
SOURCE: exhaust fan not starting
Bearings are worn. You should be able to replace with a standard utility fan. You can find them at your local big box hardware store or order online here.
www.appliancepartsdepot.com
Posted on Jan 28, 2008
Eddie Rentas
  • 59 Answers
Hi
I have all the diagrams for that model and will gladly send them to you all for free via email. Remenber that the fan will always get gresse and have to be clean, also keep the filter clean.
Let me know were to send the diagrams...Glad to Help!!
Eddie Rentas
Tupper Lake NY
Posted on Jun 26, 2008
tzweeb
  • 318 Answers
SOURCE: how to wire a jenn air cooktop JEC9530ADB
the new cooktops and ovens now have a 4th wire used for separating the ground and neutral. some new homes and remodeled homes have a 4th wire run from the circuit panel to the unit.
you dont have this but it is ok to just hook up the white and green/ground wires together. then red to red and black to black. it will work properly and thats all you have to do.
Posted on Dec 29, 2008
SOURCE: Jenn-Air JEC9530 Electric Cooktop fan rattles
When I turn a burner on I don't here the fan run. is this a problem?
Posted on Feb 09, 2009
  • 222 Answers
SOURCE: Front double burner not working on Jenn Air
mostly the problem is the sensor inside the unit but so very expensive to replace,wait to damage the other then buy an new one compare to repair.
tnx gerbee
Posted on Jul 04, 2009
Why do Jenn-Air cooktop igniters click when the exhaust fan is on med-high and the burners are on low flame setting ? ?
Igniters sense flame temperature, and if the fan cools the temp sensor down, your cooktop thinks the flame has gone out, so it clicks to reignite it.
Sep 02, 2014 | Jenn-Air Cooktops
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Sep 09, 2017 | Jenn-Air JED8430 Electric Cooktop
Stove not on - but fan comes on automatically -
it sounds as if the thermostat is broke. it could be the two wires off the thermostat are after melting together. ( burning smell). the thermostat stops power going to fan when it sences below a certain degrees. but your one has been cut out of the circuit due to the two cables melting together. this means fan will constantly stay on. you need to find and replace thermostat and make sure no cables melted together. if they are then seperate and use insulating tape to re insulate.make sure circuit breaker is off while doind this
Jan 16, 2009 | Jenn-Air JED8230 Electric Cooktop
Blown accessory fuse? jenn air cooktop jed8430adb
the unit doesnt have any internal fuses. you have a house fuse blown or circuit breaker that tripped. the fan switch can be found online or from your local parts house and make sure you get the clips to hold it to the mounting tabs.
next time you get ready to work on it, just make sure and turn off the power first as you will touch the metal terminals to the frame again.
Dec 27, 2008 | Jenn-Air JED8430 Electric Cooktop
Dec 12, 2008 | Jenn-Air JEC9530 Electric Cooktop
Switch for cook top fan
i think that there is a sub for that switch.
i tried finding it but cannot find the sub.sorry
Oct 11, 2008 | Jenn-Air JED8430 Electric Cooktop
Exhaust fan not starting
Hi
Eddie Rentas
Tupper Lake NY
Apr 03, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air Electric cooktop
did you replace the limiter the long rod that goes across the element or just the element everything i can find says that's the culprit
Dec 29, 2007 | Jenn-Air JED8430 Electric Cooktop
JENN AIRE CVGX2423 COOK TOP
short in the fan wirring.. it is not easiy fix . you need to replace the fan and short wieeing.
Dec 19, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Apr 15, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air 30" Smooth Top With Dual Element & Warming Center Jec9530bdb Logo
Top Jenn-Air Cooktops Experts
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
