Question about IBM Infoprint Color 1464 Laser Printer
Results for "107 service printhead error lexmark"
Lexmark 650n printhead Service Error 935.26
110% faulty Printhead. Part required is PN: 40x4463
Easy repair, both side panels and top cover removal then just unbolt the Printhead and replace.
Dec 02, 2012 | Lexmark Office Equipment & Supplies
Generic Ink cartridge causing printhead errors
It's not a guarantee that the remanufactured cartridges will work the same way as our cartridges. Remanufactured cartridges also voids the warranty of your printer.
For best results, always use genuine Lexmark cartridges. We do have a Smart Supply program where you will always get 10% off each cartridge purchase and free shipping every time. Check here for more info: http://bit.ly/HNG1M9
Apr 23, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
I have an error on my Lexmark T632 printer saying 933 service printhead error, can you tell me what this means
Printhead error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
First step trying to fix this is to turn printer off, and back on after 10 seconds. If this won't clear it, try and plug the printer in a different power point straight into the wall. If the error does not clear, the printer will probably require service to correct the issue.
Sep 28, 2010 | Lexmark Optra T610 Laser Printer
It will not print and is reading 935.15 Service Printhead Error what do i need to do to fix this?
Here's an article in the Lexmark website on A Printhead Error Is Appearing on a Lexmark E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/9GQzbO. If all else fails, it may require service. I would also suggest you replace the power supply.
Jun 20, 2010 | Lexmark E450dn Laser Printer
JUST INSTALL MY NEW PRINTER, LEXMARK C540 SERIES, I KEEP GETTING A ERROR MESSAGE THAT READS 100.08 SERVICE PRINTHEAD ERROR. WHAT DOES THIS MEAN PLEASE? I HAVE INSTALLED AND UNINSTALLED TO REINSTALL. THE...
Most of the time the problem can be resolved by reseating the printhead cable which can be accessed by opening the back cover of the printer. If that won't resolve the problem, I recommend to have it serviced. It's a possible defective printhead.
Apr 29, 2010 | Lexmark C543dn 26B0000 Workgroup Up to 21...
How do i know which print heads need replacing?
The HP diagnostic error codes will tell you what needs replacing. Run a self test and print test to see the results. This should identify any harware problems.
Sep 10, 2009 | HP Office Equipment & Supplies
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
931.01 Printhead Service Error
there is a Printhead error - No first sync
Dec 21, 2008 | Lexmark X342n All-In-One Laser Printer
Service printhead error 108
Error Code(s) Printhead Color
106, 111, 115, 171, 172 Cyan
107, 112, 116, 173, 174 Magenta
108, 113, 117, 175, 176 Yellow
109, 110, 114, 169, 170 Black
Power off the printer, take the Magenta cartridge out, take a lint and dust-free cloth or tissue and clean the hysinc mirror and the printerhead lens. I just did it and it took me three minutes to clean with toilet paper rolled up like a cigarette.
My printer is back on line. The hysinc mirror and printerhead lens is in the printer not on the magenta cartridge. Reinstall the print cartridge and power on. This has happened to me before with a different color.
here is the Lexmark c750 support link:
http://support.lexmark.com
I hope this helps. - This is from Joey V on fixyourownprinter dot com
Oct 13, 2008 | Lexmark C752 Printer
Lexmark C752 108 Printhead error
They mean the respective printheads have lost the HSynch.  The first thing the we do (and have had great success with) is to clean the laser lenses.  Then check the head wiring.  The following codes apply:
106 & 110 CYAN 107 & 111 MAGENTA 108 & 112 YELLOW 109 & 113 BLACK
Jan 10, 2008 | Lexmark C752 Printer
IBM Infoprint Color 1464 Laser Printer Logo
19 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
