Question about Garmin Fishfinder 160 GPS Receiver
Garmin 160 will not show depth or bottom but does temp and speed
Hey guys my 160 will not show depth or bottom but will show temp and speed. i bought new ducer and still no work. it is a in hull ducer and works great with another 160 hooked to it. who can i have look at it garmin want? thanks roger j
4 Suggested Answers
SOURCE: garmin gpsmap 550s is it
i think it is not compatible with the in-hull zero degree rise depth transducer p72
Posted on Jun 03, 2008
SOURCE: Garmin Fishfinder 160 will not display bottom
Change your setting from saltwater to fresh water even if you fish in sea water,your transducer is a 00/200KHZ and not a 50/200KHZ.
Good luck
Willem
Posted on Apr 07, 2009
MarineTech1
  • 76 Answers
SOURCE: I have a garmin gpsmap 440s that will only read
Sounds like the transducer is installed at the wrong angle or in such a way that it is getting a lot of air from something on the hull. If it is a transom mount, check that it is angled correctly and not too close to the motor or aft of some kind of thru-hull fitting that will cause turbulence.
Posted on Aug 22, 2009
What can i do to stop the flashing of the depth finder at times it will not show the current depth
Hey Joe,
Wow.. where to start.. there are so many things that will cause the issue you are describing.What type of electronics do you have? Does this happen at all speeds? Where is the transducer mounted? I need more info about when it stops reading.
1.Wrong setting on the unit
2 Bad transducer
3 Bad transducer mounting (either inside the hull or outside the hull.)
4. (In hull) Turbulence going under the boat (mine quits reading at about 55 mph @ half trim...the boat is lifting so much it causes air pockets so the transducer loses contact with the water)
5. (Outside hull) Turbulence around the bottom of the boat where the transducer meets the water.
Good luck,, when you get the info.. reply to me..
Jun 03, 2017 | Boating
How do i change time to destanation to Truck mode
You need to change the speed you have it set at
Aug 01, 2014 | Garmin Nuvi 465T Car GPS Receiver
Is it posible to conect garmin 420s gpsmap to st40 deth transducer
No. St series from Raymarine are made for digital depth only, not fish finding and do not talk nmea. The only way to get that Garmin of yours to see depth would be to go from an ST40 nmea out to that garmin nmea in. Or purchase a nmea 0183 smart sensor and hook it to the garmin.
Apr 08, 2012 | Garmin GPSMAP 420s GPS Receiver
I recently bought a boat with this type depth finder on it. It was working fine until I was unable to get off a local beach that people commonly pull up on. The water ran out and the entire bottom was...
Hi, make sure that the bottom of the transducer is parallel to the bottom of the boat. It probably has been knocked upwards while on the beach. If not the transducer will need to be replaced. Hope this helps, regards Phil.
Jun 06, 2011 | SI-TEX Sitex Cvs106lmkii Color Lcd With...
My Garmin 498C will not show the contore of the bottom or give me a depth reading. The GPS works and will show me charts but, not the sounder option though.
You need to check to see if the depth sounder transducer is connected or functioning. It might be turned off, the connectors may be bad or the transducer is bad. I don't have the 498 manual in front of me but I think there is a test function under the setup menu. I'd check my connections (the usual suspect) then run that.
Garmin tech support is pretty good/quick. So don;t be afraid to give them a call.
Aug 29, 2010 | Garmin GPSMAP 498C Sounder GPS Receiver
Depth and fish finder screen up but no #'s temp., depth etc
You can contact Garmin Customer Support
North America - Consumer Products
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Feb 07, 2010 | Garmin GPSMAP 3210 GPS Receiver
Garmen 240 fishfinder
A test bucket wont work, A 200 khz transducer will generally not work in anything less than 2' of water, due to surface clutter. If the transducer is working, you should hear it make a ticking sound.
When you got the 17000 foot reading was your range set to auto?
How is the transducer situated on the boat? Sometimes turbulence and bubbles from the hull can cause erroneous readings, including unrealistic depths, or no depth at all. Stop the boat and turn off the engin e and anything electrical to see if problem repeats itself. If it only crops up when the boat is moving then it is most likely the transducer location.
Jul 26, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Depth display
reset your factory settings!
Oct 02, 2007 | Garmin GPSMAP 498
NO DEPTH READING
Check the finder on the bottom of the boat and make sure the cable is ok?
Aug 09, 2007 | Garmin 185 Sounder GPS Receiver
Garmin Fishfinder 160 GPS Receiver Logo
202 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
