Question about Garden
Snowblower motor doesn't turn over - Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Electric? Gas? Electric start? Pull Start?
Help us
Posted on Jan 08, 2014
Snowblower always in gear and wont throw snow and cant move when engine is off
Service kit available for that mess of gears in the motor box(needle bearings inside the gear seize up), there is also a shear or sacrificial adapter mounted to the impeller input shaft Parts and Diagrams for MTD 31AS63EF729 2011 check around part # 7 and 15 top right hand corner. hope this helps. if this didnt help check out this web site
Feb 05, 2014 | Garden
I need to know how to adjust the governor on my MTD model 31A-62EE729 snowblower with a 179cc motor
lossen the nut on the governor shaft, and move the arm toward the carb while holding the arm in this position turn the shaft counter clock wise and tighten the nut. and you are done. GOOD LUCK
Sep 03, 2013 | Tecumseh Snowblower Snow Blower Starter...
Swisher 27" snowblower front impellers turn free
Hi Craig,
Most snowblowers incorporate "shear pins" between the motor and auger. A shear pin looks similar to a nut and bolt or pin that couples the drive to the auger - but it designed to break or shear off to prevent damage to the auger or motor in the event of a jam or overload. They look like these:
Only the shear pin recommended for your particular brand and model snowblower should be used. Under no circumstances should a regular bolt or other steel pin be used instead of a shear pin. Check your manual or consult with Swisher to determine the correct shear pin for your snow blower.
I hope this helps & good luck!
Dec 21, 2012 | Garden
We have a yardworks snowblower and when not using the wheels always lock up. how do you unlock them without turning on snowblower.
Had the same issue and found out that the wheels lock when the motor isn't running and the accelerator handle is engaged. I still had both handles tied down from transporting home and it rolled fine after they were untied. Hope that helps
Oct 21, 2012 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Bad switch on Electric Started
hello,if it is the one i think it is to where the push button is a closed unit with no screws as far as i know there is no repair for the push button switch,how ever there is a good how to on u tube repairing snowblower electric starters,from what i have seen the push button doesn't go bad,now if the push button comea apart you can repair it which useally the black box or circut thing that cost around $40.00 found on most s 200 blowers,hope this helps,,
Jan 23, 2012 | Garden
My toro snowblower keeps stalling. It starts up fine, but won't run continuously.
If you haven't already, dump out gas and put fresh in it and try this, if it doesn't work you will have to clean the carb, take it apart and clean all jets ports etc and put back together and you should be Good to Blow Snow, pretty common problem with Small Engines that set half the season.
Dec 04, 2011 | Garden
Snowblower slower/no blowing force.
Electric motor may have a shorted winding, better would be the belt is slipping...... Sparks tell other wise.....
Feb 10, 2010 | Kitchen Appliances - Others
Honda snowblower engine hunting
Sounds like you are hitting the governor. Watch the arms at the carb when you move it to full throttle. The arm should hit a screw. Turn this screw clockwise, until the reving stops.
Dec 08, 2008 | Garden
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
