Question about Horizon Exercise & Fitness
Elite 507 speed sensor
How to locate
3 Suggested Answers
SOURCE: change speedometer readin on elite 507 treadmill from mph to kph
I know this is an old thread, but if you are still trying to change between mph and km, then follow these instructions.
The setting is changed by a switch on the console circuit board. Unplug the power cable. You will need a medium philips screwdriver. The console is fixed to the frame with 4 screws, climb under the console and remove 2 screws from the top and 2 screws from the bottom. Get back up and lift the console up slightly making sure you do not dislodge any cables from either the left or right-hand side of the console. Look under the console from the left-hand side, in the middle of the circuit board you will see a small slide switch (silver casing with black slider), slide it to the other position. You will see next to the switch the letters mph and kpmh. gently reseat the console, put the 4 screws back in, the console should now display the speed in kmph when you plug it back in and turn it on.
All the best
Posted on Feb 24, 2011
ercupa190
  • 12223 Answers
SOURCE: elite 507 problem
LUBE THE machine inmediately, and proceed according with the instruction manual maintenance. 2) The deck belt can be worn for lack of lube. this produce enough friction for shut down. 3) Inspect the drive belt and replace if necessary 4) Test the input voltage motor if there are the motor need repair 5) Test the output voltage main motor board, for input voltage motor if there are NOT, the board is faulty.
Try to RUN the software calibration for diagnose and trobuleshooting
sincerely. God bless you.
Posted on May 03, 2012
I have two code error on my jeep grand Cherokee 2007 idle air-control p0507 x3 of them & p2767 input/turbine speed sensor B, could you help me get idea, of what it is?
code p 0507 refers to idle speed control (ISC) system rpm higher than expected==causes -wiring--ISC actuator/IAC valve --throttle motor -- throttle valve tight / sticking---ECM
it als o refers to idle air control(IAC) system--circuit low===causes --wiring short to ground --IAC valve ---ECM
code p 2767 refers to transmission input shaft speed sensor/turbine shaft speed (TSS) sensor B---no signal===causes --wiring---transmission input shaft speed sensor /TSS sensor
Mar 26, 2016 | Jeep Cars & Trucks
Altima code 507
507 is a catalytic converter code that the computer throws when the oxygen level is below 95% of max. Altima's don't generally have that issue so i would lean more towards an 02 sensor. usually its the upper 02 sensor. start there.
Dec 01, 2012 | 2002 Nissan Altima
Elite 507 problem
Apr 29, 2012 | Exercise & Fitness
Sharp AR-507 "Close the document feeder" error even it is already close...any suggestions and solutions please...
The document feeder has some kind of plastic nose that goes in to the sensor hole. Locate it and check for damadges.
Jul 05, 2010 | Sharp AR-507 Copier
I have the horizon elite 507 treadmill, how do I move the tread back to its normal position using the blue tool? thank you
Is it all the way over to one side? Is the belt damaged on one side? If it is damaged you will never get it to Track correctly.
If it is not damaged, then start the treadmill moving at about 2.5 mph, if the belt is all the way to the right then turn the right rear roller adjustment bolt, clockwise one full turn, and wait. did the belt move over a little? if yes the increase the speed to 5.0 mph and observe.
Make small adjustment from one side only until you get it straight.
Jul 05, 2009 | Life Fitness T3 Treadmill with Advanced...
Change speedometer readin on elite 507 treadmill from mph to kph
All the best
Jun 12, 2009 | Horizon Exercise & Fitness
Sharp AR 507 has a code L3-00 Scanner will not retun home in time
It could be the Mirror Home Position Sensor malfunction, it's located at the upper left section of the upper frame, if the copy lamp is in its home position, there's a lever/part of the copy lamp that actuated this photo sensor. Try clean that tiny gap with a hand blower, if L3 still occur then you should change it.
Mar 11, 2009 | Sharp AR-507 Copier
Exercise & Fitness Logo
24 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
