Question about Craftsman Garden
How do you remove the driven wheels on a craftsman self propelled mower
On mine (front-wheel drive, about 8 years old) you first remove the plastic hubcap from the front wheel - then there's a big nut holding the wheel on. The hubcap just pops right off. I used a skinny, regular screwdriver to do it.
Posted on May 22, 2009
I have a Craftsman front wheel self propelled mower. The front wheels no longer turn either in self-propel or in manual push mode. What can be done to fix this?
Take a good look at the wheel assembly. Is it rusted on from being left exposed to the elements? Remove the cover for the self propelled mechanism. Is the drive belt intact? Try turning the small pulley.
Aug 20, 2016 | Craftsman Garden
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
Self-propelling action on 917.378771 not working
This type of mower uses a gear box driven by a v-belt. First check the v-belt. Is it in place and does it turn when the drive is engaged. You can also check the drive pinions in the wheels. These can wear out or "chew up" the insides of the drive wheels. I doubt it is the transmission, these are tough little units on this mower.
May 04, 2015 | Craftsman Garden
Ned a rear wheel replaced on self-propelled push
look on craftsmans website and see it they have the wheel or look on partstree.com and they might have it!! have fun!! :)
Apr 01, 2010 | Garden
Wheels will not turn on craftsman rear bagger lawn mower
Is the lever pushed up where the self propelled should be engaged? Yesterday, my wheels stopped turning. I have a break in the cable that goes to the self propelled. I will have to replace the cable.
Mar 27, 2010 | Garden
My craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Sep 04, 2009 | Garden
Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Aug 16, 2009 | Garden
Need instructions how to install belt on self propelled craftsman push mower
raise the front of your mower up and support it with something safe like a jack stand
take the blade off
when your blade is off locate the plastic cover covering the belt and remove
now remove the belt but first remove the plastic cover on top of the mower to uncover the gearbox that turns the wheels your belt goes from the engine pulley to the gearbox pulley
you will have to work the belt off the pulley while turning the motor by hand or the same when installing the belt.
to install belt reverse the procedure.
hope this helps some
Jun 06, 2009 | Mtd 22" White Outdoor Self Propelled High...
I have a 7hp briggs and straton craftsman self propelled push mower. It's a few years old but runs great, the only thing wrong is the self propelled part won't engage. I took it apart down to the axle but...
Could be a stretched out/broken belt, a worn out transmission or the drive teeth on the inside of the wheels could be worn out. I would start by looking at that. Remove the drive wheels and check for damaged or missing teeth.
Apr 20, 2009 | Craftsman Garden
Garden Logo
367 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
