Question about True GDM-12 Refrigerator Commercial
Freezing no matter how the stat is set.
Is the thermostat bad? how to replace it?
Scotsman icemachine constantly freezing up no matter how small you put the setting?
Max harvest cycle just keeps it in a harvest longer. if you set the freeze setting to its lowest point and ice is still to thick then replace the freeze stat.
Feb 22, 2015 | Scotsman Ice Machine, Cuber, 1930 lb....
Dca213d window unit keeps freezing is it thermostat?
Check for badly bent fins or obstructed/dirt impacted fins on the outside of the unit. Could also be low on gas. Try setting the t/stat to various settings see if its turning off/on at higher settings, if it does most likelt stat is OK. Also make sure you drian is clear.
Aug 12, 2014 | Carrier Heating & Cooling
Fridge keeps freezing
Can't solve your problem, but just to report we have exactly the same issue, a huge block of ice forms on the upper rear panel. The compressor seems to be running 24h, not matter where the 'thermostat' is set.
I suspect that there was/are a faulty batch of thermostats. Or (since there is no metal cooling plate to bolt it to) that the T/Stat probe has somehow come adrift from its correct sensing area and is not correctly sensing the temperature inside the fridge.
If I get to the bottom of the problem, I will re-post here.
Dec 06, 2009 | Refrigerators
Temperature control does not work. Unit freezes everything no matter where the temperature control is set (Marvel Wine Refrigerator)
Either the thermostat itself is bad, or the relay is sticking. If you break the connection between the T-stat and the relay, and it keeps runnning, the problem is the relay.
If the compressor stops running when you break the connection or disconnect the T-stat, then the T-stat needs to be replaced.
Oct 12, 2009 | Marvel (6SBARBSG) Wine Cooler
Thermostat issues
I would suggest a thermostat replacement. if the stat is losing its program and it has power there is really no other alternative
Jul 09, 2009 | Heating & Cooling
Too cold, ice machine wont work
Bad thermostat or T stat set too low. Set the T stat in the freezer between 2 1/2 and 3 1/2 and see if that helps. Same goes for the "cold control" in the refrigerator part of the cabinet. It should be set at about the same setting as the T stat and then adjusted for temperature once the unit settles down.
If the fridge just "keeps on running" and never shuts off except to defrost, the T stat is bad and needs replaced.
As far as the ice machine. that's a common problem. Don't waste your money getting it fixed, it's not worth it because it'll just break again. A self contained home ice machine is cheap and lasts forever. It makes more ice faster and can be put anywhere you want it.
Jul 09, 2009 | Refrigerators
Home air conditioning too cold at "Fan On" setting
Sounds like you have a wire shorted between y and g somewhere. Maybe a bad tstat. email me if you have more problems james3751@gulftel.com and I may be able to walk you thru the troubleshooting
Jun 02, 2009 | Honeywell Electronic Programmable...
Freezer freezes and then thaws
check wiring into outlet and at breaker that feeds outlet. you may be losing high volts at or to the switch. if possible check power into the stat when the condition occurs. this will telll you if stat is bad or power into it aka the outlet is bad. you may be jiggling wires in the outlet enough to fix short term each time you replug to outlet or get a good heavy extension cord and plug in else where to seee if problem goes away.Good luck
Dec 06, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
True GDM-12 Refrigerator Commercial Logo
26 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
