Question about Exercise & Fitness
I have a strength master ma200 the pannel saftey key is broken so the keys ids not working
Pannel shows zero and any keys is not working the saftey key is broken what should i do my machine is not working
4 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: i have lost the saftey key for my power run 2000
is very difficult to do it without the safety key.
I recommend you for measure of security , to buy a new ones.
You can buy from your supplier dealer, or you can go:
www.fitnessrepairparts.com
sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a
Posted on Dec 22, 2011
ercupa190
  • 12223 Answers
SOURCE: i lost my saftey key, can i use any treadmill saftey key
Dear Sir:
Please you have 2 options:
1) to buy the key from www. fitnessrepairparts.com
or 2) go to Hardware and buy a small magnet, since the key is a magnet!
sincerely. God bless you.
Posted on Apr 28, 2012
ercupa190
  • 12223 Answers
SOURCE: where does the saftey key go, insert?
the safety key go in display board, see your instruction manual and proceed according.
if you do not have free for download : www. fitness.manualsonline.com or www.iconservice.com or www.manualsfactory.com
God bless you
Posted on May 16, 2012
ERROR 6 OCCUR IN STRENGTH MASTER MA200 TREADMILL
Hello.
This is will be the speed sensor not responding.
Take the motor cover off.
Find the small belt coming off the motor and on to the roller.
Look on the side of the front roller for a magnet, you might just find a hole, if this is the case the magnet has fallen out and will be stuck on the inside frame somewhere.
Glue it back in and test machine.
GymWorld.net.au
Jan 10, 2014 | Exercise & Fitness
StrengthMaster MA 200 Treadmill
i have a treadmill strength master ma200 and the safety key is broken the pannel shows zero and no keys is working
Jul 23, 2013 | Exercise & Fitness
Does a 1987 gmcjimmy s-15 have a power window relay ot any relays at all cuz my power windows stoped working it runs a 30 amp circut breaker can the circut breaker go bad?
Anything can go bad, but to my knowledge circuit breakers seldom do. If you have a test light, pull the circuit breaker and probe both terminals for a power signal, with the key on. One terminal should show voltage with key on. If not, check the power distribution box for a blown maxi-fuse, or the wiring from that box to your fuse panel.
BTW, no, no relays are in the window circuit. So if the circuit breaker has power to it, put it back in and check for power on the driver's door master switch-one wire on the master should have voltage with key on. If no hot wire to the master switch, check inside the door openings for a broken wire. If you do have one hot wire there. check the power windows ground-the ground wire for the power windows originates at the master switch and goes back into the cabin to a nearby ground. Put one lead of the test light on the hot wire (key on), and probe the ground terminal at the master switch-if your ground is good, the test light will light up. If the ground is lost, no light. Check for a broken ground wire in the door opening, and/or find the ground and see if it is bad. If the master switch has a hot wire and a good ground wire, replace the master switch.
Apr 25, 2013 | 1987 GMC Jimmy
I have a EPC notebook computer Model #MA200 I
Hi
please try pressing the FN+F5 keys together to see if this enables the keyboard
many thanks
Jul 19, 2011 | ASUS Eee 1000HA (EPC1000HAWHI001X) PC...
Caller ID does not work until call is answered.
To set up call id you need to enter programming2.gif . Programming is done on M7310, M7324, and T7316 sets only. Press the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
Sep 24, 2009 | NorStar M7310 Phone
Java error no memory available
Source: http://en-gb.facebook.com/notes.php?id=49358857278
13.Dial *#6984125*#
14.Go to Internals (Master Key: *#9072641*#)
15.Go to Storage Settings and select Update Java DB
VODAFONE USERS TRY THIS CODE!!!
13.Dial *#3695147*#
14.Go to Internals (Master Key: *#3971258*#)
Apr 12, 2009 | Cell Phones
No Caller ID on display
To set up call id you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
that should do it providing you have caller id service though your local telco provider.
Mar 25, 2009 | NorStar T7316E Corded Phone
Forgot my unlock code
forgot to unlock my motorola i855e phone number
Jun 24, 2008 | Motorola Mobility i855e Pay-As-You-Go Cell...
Cell phone problem
if you go to menue settings security then phone lock and lock now or auto lock you defalt security code is 1234 for the slvr if you bought your phone second hand id preform a master reset on the phone first and reset all settings back to factory if you want to try that to its menue settings initial set up master reset and def is 6 zeros 000000 hope that helps you
Feb 20, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Exercise & Fitness Logo
113 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
