Question about Frigidaire Dishwashers
Where is the reset button on my dishwasher
Cl code
4 Suggested Answers
SOURCE: Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Posted on Sep 09, 2008
  • 500 Answers
SOURCE: Our dishwasher continuously flashes "CL"
Hi trrhodes,
I believe the CL you are getting means "Child Lock". Under normal circumstances there should be no activity at all on your machine.
Please do the following:
- On the Facial Panel (Where the buttons are located), look for 2 buttons marked together with a line, it should also have a face of a child somewhere on that line.
- Press both these buttons together for 3 - 5 seconds, this should reset the Child Lock.
Kind Regards :-)
Jacques
*If you found this solution helpful, please rate it
Posted on May 26, 2011
  • 19 Answers
SOURCE: Dishwasher is giving a CL code when trying to push the start button, door is closed.
you need a new door switch. this was a very common problem with these machines when they first came out. The dishwasher may be closed but one of the switches is staying open so the computer things the door is open.
Posted on Nov 16, 2012
My dishwasher FDB2510LCC1 get a cl code while washing and stays running on the wash stage until it is shut off
Hello Randy, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher is displaying an error code of "CL" this means close door. The dishwasher may not be sensing that the door switch is closed. The "CL" means that you could have a possible issue with the main control board or door latch. I would recommend checking to make sure the latch does not have any visible damage. This could also be a miscommunication within your dishwasher and a reset may help clear it out. In order to reset the dishwasher you would flip the household circuit breaker off for at least ten minutes. We hope this information is helpful to you. -Matt
Jan 28, 2016 | Frigidaire Dishwashers
Frigidaire Gallery Professional Series GPD8998JC0 ... I can press the buttons to choose my settings but my START/CANCEL button won't work. So I try a 1 hour delay which works but then no water nor the...
Hi Joseph - I understand your dishwasher is displaying a "CL" error code. A "CL" code typically refers to the main door switch. The first easy troubleshooting tip is to flip the circuit breaker to the dishwasher for about 20 minutes and see if that resets it and clears the error. If the circuit breaker trick doesn't work, it could potentially mean that the door is not closed completely. However, it could also mean that the control board is not sensing that the door is properly closed. I would recommend checking the door switches. Look to see if you notice if anything is bent or misshapen. Also, you might try the manufacturer site to see if you can download an owner's manual for future reference. They typically have a large number of owner's manuals for consumer use. If you have tried these troubleshooting tips and still come up with a "CL" code, you might need to reach out to a local service tech who can better pinpoint the problem for you. Best of luck!
Dec 19, 2013 | Whirlpool GU2400XTP Built-in Dishwasher
Frigidaire dishwasher model FDB2320REC0 when I push the normal wash CL flashes
Hello linda_ross88 - Typically CL indicates that the main control board is not sensing that the door is properly closing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, typically an expert would need to check the door switches, wiring, and test the main control board. Regrettably, this is not a simple DIY job. I would strongly recommend seeking a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
Mar 18, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Nov 15, 2012 | Dishwashers
Frigidaire gallery dishwasher CL code
CL is a generic clear code. Reset the unit at the household circuit breaker for about 10-15 minutes, and then retry. If the same code comes up then you have a communication error with your main control board, and will require a repair.
Aug 30, 2012 | Frigidaire Dishwashers
Won't start CL flashes
Hi catherine739,
The CL you are getting means "Child Lock".
Kind Regards :-)
Jedemeyer1
Jun 09, 2011 | Dishwashers
Hi trrhodes,
Kind Regards :-)
Jacques
May 23, 2011 | Dishwashers
CL stays on
Generally, the reset buttons are marked with a small dot by them, there are usually two and they should be presses simultaneously while the machine is on for approx 5secs. (Should say 'reset' or 'cancel drain') The two buttons are usually separated by one of the other buttons.
Alternatively, the unit may reset by keeping the starting button pressed for 5 secs. (if it has a start button).
Hope this helps.
Jul 23, 2010 | Bosch SHU5315UC Dishwasher
Dish washer does not turn on CL light stays on when reset count down 6 appears then goes to CL
Hello and welcome to Fixya,
I have a ton of service info on Bosch so it`s best I post you an exert from the service pdf`s I have on my PC which will explain the meaning of "CL" and then go from there. This is not a common indication of a control problem, but it could be a problem with the plastic casing which houses the control, we`ll deal with that later.
I`ve underlined the section pertaining to the "CL", this is for the SHU68** dishwashers only.
TO OPERATE:
First depress the On/Off Button until it locks in place.
Once the On/Off Button is depressed the LED above the previously used cycle will illuminate.
To change the cycle, simply press the desired Cycle Button twice. The LED above that cycle will then illuminate.
The Cycle Countdown will display an approximate run time for the cycle chosen.
This run time will depend on incoming water temperature and the turbidity of the pre-wash water.
Note: It is normal for the Countdown Display to remain at a time increment for more than one minute, or skip a time increment depending on the calculations of the Control Unit. Also, with continued use the Control Unit will learn the wash and temperature patterns for the most commonly used programs and will then reduce the overall start and running times.
At the end of the cycle the display will show a CL, indicating that the cycle is complete.
**TO CANCEL A CYCLE:
Press the Scrub Wash and Delicate / Econo Buttons both in at the same time. The unit will then drain and the figure CL will appear in the display.**
DELAY START:
The Delay Start feature allows the unit to be delayed for up to nine hours. To program, start the unit as described above, but after selecting a cycle push the Delay Start button. The display will show a 1h, or one-hour delay. Continue to depress the Delay Start Button until the desired delay time is reached (up to nine hours, 9h).
The unit will begin automatically once the delay time has elapsed. To reset the delay, press the Delay Start Button until it reaches 0h.
TOP RACK ONLY:
The Top Rack Only feature can be used in conjunction with any cycle. To active, press the Top Rack Only Button after selecting a
cycle, the Top Rack Only LED will illuminate and all water will be diverted to the upper wash arm for the complete cycle.
REFILL RINSE AGENT LED:
The Refill Rinse Agent LED is activated via a Reed Switch on the Detergent Dispenser, Section 4, Fig. 8-3. The LED will
illuminate when the Rinse Agent Dispenser is empty.
Service note: The Refill Rinse Agent LED will also illuminate when the dishwasher door is opened and then
closed even if the Dispenser is full, but will only remain lit for a few seconds.
“F” CODE:
An “F” in the display window indicates a filling fault.
Please note: If the door is opened during the cycle, the On/Off Button will be reset to off and must be depressed again to re-active the cycle. The cycle will resume from where it left off.
Now that you are equipped with this info, what I`d suggest is trying the **cancel option. ( ** see above )
Once you`ve tried the cancel option, select a Regular Wash and post back what happens and I`ll try to assist you from there.
Good luck.
macmarkus :)
May 14, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Mar 14, 2008 | Dishwashers
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
