Question about T-Mobile Sidekick® 3 Cellular Phone
Dead Phone? I was given a used side kick 3 the D Wade one there is no ac adapter but i do have the USB cable. I plugged it in but nothing happens. The power button dose nothing i have never had a side kick any suggestions? Thanks in advance
    President:
  • 625 Answers
The D-wade sidekick 3 uses a charging port. You should see a little round plug in on one end of the phone. you will need to get a charger from eBay. They are about 3-5 dollars shipped.
The usb cable is only used for transferring data, no charge capability exists for it
Posted on Oct 06, 2009
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
Dell latitude 610 AC adapter issue or battery pack issue or both?
It could possibly be the power jack that is inside the computer. This item is typically soldered onto the motherboard and it is what your ac adapter plugs into.
Dec 21, 2007 | Twinhead SlimNote N12PI Notebook PC
I have a toshiba laptop about 2 years old. I didn't use it for a few days and now it won't turn on at all.
was it plugged in when you tried to turn it on?
if not, try charging it for a couple of hours. the battery must be completely empty
other than that I might need more details
Aug 07, 2011 | Toshiba Computers & Internet
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
We just tried to start our wii and it want turn on. Any Ideas as to what we should try? We did hit the reset button and nothing happened. My son went to his house about 3 miles away and found his to be...
Odds are there was a power grid surge (especially given the fact that your son's is dead as well. Typically replacing the Ac adapter (power cord) will fix the problem, the ac adapter is designed to take the blow in the event of a power surge.
Dec 27, 2009 | Nintendo Wii Console
How do I connect my cect i9 3g to my computer? There is no cd to install. I tethered it with the cable but nothing comes up?
use the usb plug/ac adapter switch cell to usb connection...go to my computer u should see the cell phone memory or micro
Aug 18, 2009 | Dual Electronics CECT P168 Cellular Phone
Toshiba satilite P100...wont turn of
Try these:
1. Can you plug something else besides your laptop into the outlet...verify you have power?
2. Is there a light on your AC adapter...when you plug it in?
3. Try removing your battery and plugging it in, and verify that your AC adapter is working (somehow, if it has no indicator light)
4. Then unplug it, put the battery back in and see if it will start.
Let us know what happens after you try these.
Apr 12, 2009 | Toshiba Satellite P100 Notebook
My GPS won't turn on.
I had this issue also. When I got it out of the box, it had maybe 30 minutes of playtime without a charge before the battery went low. I used the USB it came with and found plugging it into my laptop AND desktop does absolutely nothing; even though the magellangps.com states the USB can be used as a charger on the PC.
It's been less than 8 hours since I've had it, and I have not gotten a chance to use the car adapter to charge it... I have a DC/AC unit inside my house which I am using to charge the unit and it works fine (incase you dont know what a DC/AC adapter is; its pretty much a lighter adapter that plugs into the wall).
MAKE A LONG STORY SHORT -
With my migraine starter experience with charging and powering on; I have read on 100's of Magellan 3250 reviews that cold tempratures cause these issues.
Other possible causes:
Battery is 100% dead = leave it in your car charging (HIDE UNDER THE SEAT!)
If the USB port plugged in charging in the car; if it is still not working, make sure that the FM part is also plugged in. I found that my GPS does not charge with just the USB end plugged... At least for me, it will only charge with BOTH ports plugged....
I hoped my novel helped... If it didn't; return your Magellan, and buy a GARMIN GPS. I have a Garmin that I bought for my hubby, and 2 years later, has never once experienced any issues.
May 09, 2008 | Magellan Maestro 3250 GPS
Power will not turn on??
Try this:
1. unplugging the power cable
2. removing the battery
3. plug in power cable
4. switch on and start up
If this works, shut down, unplug and replace the battery.
Hopefully your problem is resolved.
John (Computer Tuition, Blackpool)
Nov 08, 2007 | Compaq Presario 900 /1500 Series EVO...
Dead laptop
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Aug 27, 2007 | Compaq Presario M2000 Notebook
T-Mobile Sidekick® 3 Cellular Phone Logo
65 people viewed this question
Top T-Mobile Cell Phones Experts
Computer Repairing
Computer Repairing
SHIVAJI YADAV
SHIVAJI YADAV
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
