Question about Hotpoint Aquarius WF215 Front Load Washer
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
Its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Posted on Oct 19, 2007
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
My indesit wib111 wont go ignto o spin cycle or empty.it fills and washes ok
Washing Machines do not spin when filled with water for obvious reasons. Have you checked the filter? this could be blocked with a build of fluff etc.
Can you hear the pump running when it is supposed to be emptying. This means there is a blockage. Can you hear a "humming" This means the pump is jamed, may be a coin or some other small item. If there is no sound then the pump is most likely at fault.
May 04, 2012 | Washing Machines
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
It wont complete cycle and empty the water just hums for a while and then turns its self off
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
My washing machine wont drain the water
if its making a humming sound the pump may be blocked turn the pump fan by hand to see if its free,
Mar 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Hotpoint Aquarius WF215 Front Load Washer Logo
406 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
