Question about LG Refrigerators
Grb207tuja panel not working
I have an LG American fridge freezer GRB207TUJA which the edge where the doors close on is very very hot
This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 25, 2016 | LG Refrigerators
I have an LG fridge freezer grb207tuja but the fridge is freezing everything. Anyone know what to do? Thanks.
if you have a temp control change it. make sure you are going in the correct direction with the dial. if it is on the door, change it. check your owner's manual too.
Mar 05, 2015 | LG Refrigerators
Removing LG refrigerator control panel
Put your model number into a repairclinic.com or go to YouTube.com there should be a video on either site showing you how to remove that panel
Mar 02, 2014 | Refrigerators
2003 chevy trailblazer driver door controls don't work, interior light won't work when driver door is opened. The other three doors work ok
There two common problems with the driver's door control panel, rain water gets into the module and damages the electrics or the wires in the door boot break or abrade and short out. To check out the control panel itself, take the passenger side panel and hook it up to the drivers side, if everything works, replace the driver's panel.
Dec 16, 2012 | 2003 Chevrolet TrailBlazer
I have a whirlpool electric glass top stove (model # rf364pxpq ). our electricity went out for only a moment, and when it came back on, the control panel is blank and the oven doesnt turn on. the stove top...
I just encountered the same problem. Power surge during storm caused the control panel to go blank. I removed the panel to get the part number. Reinstalled control panel and it started working. Below are the steps 1) Turn off breaker 2) Unplug unit 3) Remove rear panel 4) Unplug all connections to control panel 5) Wait 5-minutes 6) Reconnect all wires in reverse order 7) Install rear panel 8) Plug in unit 9) Switch breaker to on position Control panel came on, set clock and all oven functions worked.
Jan 02, 2011 | Whirlpool Kitchen Ranges
The driver's side control panel won't work. i.e;
There's a 50 amp fuse in box under hood. Could be the problem as far as I can tell there are no fuses in car. Check all connections. This just happened to my car. I tried using my passenger side panel an drivers side and drivers side window starting working. I put the drivers side panel on the passenger side and all other functions worked except my initial problem. I found my main auto switch on drivers side panel was bad which was causing all other functions not to work.
Jan 06, 2010 | 2004 Jeep Grand Cherokee
Problem with microphone
most of the old motherboards dont support the audio and mic port to work both in back side(back panel header) and front side (front panel header)simultaneously...
most of the old motherboards dont support multi streaming so you cant make both the back panel header and front panel header to work at a time ie i mean you cant connect both panel header at a time ...
you can just refer to your motherboard manual for the detailed information about it ..
in your motherboard if there is any option to connect the front panel header to the motherboard other than the back panel header you can connect it to that the detailed pin information will be given in the motherboard manual ..
if you dont have the option in the motherboard to connect the front panel header seperately then you must remove the pins connected from the back panel header and you must insert the front panel header pins .
this will disable your back panel audio ,mic,linein functionalities but you will be able to connect in front panel header , this front panel header will work ..
if the motherboard is not compatible then the system assembler will leave the front panel wires not connecting to motherboard ..
like this only one panel can work at a time ,
but in the latest motherboards the multi streaming technology has been introduced so both the panels can work at a time and can play different audio on 2 different panels ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Aug 10, 2008 | ASUS P5VD2-MX SE Motherboard
Refrigerators Logo
12 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
