Question about Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer
Dark streaks on copies
I am getting heavy dark streaks on my copies. What is wrong? And what can I do?
  • Konica Minolta Master
  • 6,161 Answers
Replace the the drum iff not that the the fuser
Posted on Jul 04, 2016
2 Suggested Answers
  • 92 Answers
SOURCE: makes dark line on paper
if you are using your doc feeder check and see if there is anything on the small glass the one that is about an inch wide other then that could b fusing or drum issue
Posted on Jun 26, 2009
Dark streak on copies
Drum, wiper, or fuse rolls. Pull out toner unit see if you can see those lines.on the drum.
Jan 16, 2014 | Xerox XC830 Copy Machine Refurbished
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Have a canon c130.changed toner and still getting dark streaks on copies. Have cleaned all I could find inside still dark streaks
    Try doing a "stop test." You would induce a jam before the paper reaches the fuser.
    Just open a cover while printing and hopefully some image has been transferred to the paper. If the defect exists already then the laser unit, or document scanner may be causing it.
    If that eliminates the dark streak, then obviously the fuser FG6-3720-000 should be changed.
    Whit
    Item, Inc
    Aug 18, 2010 | Canon C130F Black and White Copier
    New toner but still have dark streaks
    IF YOU ARE ONLY GETTING THE LINES WHEN YOU PUT THE DOCUMENTS INTO THE TOP FEEDER AND NOT FROM PRINTNG TO COPIER OR IF YOU PUT A COPY ON THE GLASS UNDER THE DOC FEEDER AND NO LINES APEAR CHECK THE SMALL GLASS WINDOW UNDER THE DOC FEEDER THERE MAY BE SOME TIPEX OR INK RUBBED OFF AND LEFT ON THE GLASS THERE.. THISD MIGHT BE CAUSING THE STREAKS YOU CAN CHECK THIS BY PUTTING THE PAGE IN THE DOC FEEDER AND DOING A COPY AND THEN PUT IT ON THE GLASS PLATE UNDER THE LID AND DO A COPY OR IF HOOKED UP TO COMPUTER DO A PRINT JOB.. IN NO STEAK APPEARS YOU CAN BE SURE ITS ON THE THIN SCANNER GLASS.. GOOD LUCK ...a
    Jun 24, 2009 | Xerox XC356 Copier
    TV has dark streak on one side of screen.
    Your TV has a bad light tunnel. This part is inside the light engine. A qualified tech will have to replace it, but the part is available. Once it is replaced the TV will be as goog as new. Please take time to rate this solution and let me know if I can be of further assistance
    Dec 13, 2008 | Samsung HL-S5687W 56" HDTV
    Dark streaks
    Dark streaks are an indication of "burned" or overheated ink. This will occur when the printer sets for a long period of time and nothing is printed. The problem will usually disappear after 50 pages or so, unless the printhead is damaged.
    If the print remains dark, the printhead will need replaced.
    (Very expensive)
    (Dark print can also be caused by using Non-Xerox ink)
    Sep 10, 2008 | Xerox Phaser 8400 Laser Printer
    Copy Quality Problem for Thiashen
    bit vague...Cq not good? What does that mean?
    Light copies> could be related to toner or ROS unit (laser unit)
    if prints OK but copies U/S clean mirrors and ccd lens
    Dark copies , streaking? Cleaning blade /drum unit U/S
    or could be streaking from fuser roll
    Patchy copies , dark edges, light edges ???????
    more detail please
    Feb 02, 2008 | Office Equipment & Supplies
    Copies Coming out Dark
    Please give modell number and name. Cant give you a advice out into the blue :-)
    Sep 11, 2007 | Brother 6-In-1 Printer/Fax/Copy/Scanner
    Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer Logo
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Ben
    Ben
    David Burkhart
    David Burkhart
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
