Question about 4-Seasons 2004 Chrysler Intrepid Fan Motor
Blowing cold air over heating... then suddenly we have heat
Driving on the hwy car was blowing cold air we then over heated.. we pulled over and waited until it was cool.. we added antifreeze and continued to drive. We then over heated again. we pulled over and waited then turned around and came home.. still blowing cold air. Almost home when the heat just came on?
  • 8 more comments
  • Thunder64 Jan 03, 2014
    I called my Mechanic he said i have an antifreeze leak and will probably blow a head gasket or heater core uggg....
  • Wayne Conlon Jan 03, 2014
    Are you losing antifreeze
    Did you have to put antifreeze in it again
    after it over heated the first time yes we did put in half of jug then when we got home we filled it again... there are no visable leaks anywhere...
    i drove it today... everything seems fine.. however, I just stayed in town
    If you were low on coolant a second time and youre not leaking on the ground then your head gasket is blown. Did he put the cooling system under pressure to see if the pressure went down?
    no he just poured it directly into the overflow... we dont have a pressure tester..
    but it drove today and was pumping out heat as normal.. I was hoping the thermostate was just stuck... ugg sounds like a big pricey fix!
    Take it to a mechanic and have him pressure test the cooling system. If it holds pressure, then its the thermostat. If it doesnt hold pressure, then its a head gasket
  • Thunder64 Jan 04, 2014
    well thats what I will do... thanks
    Problem Solver:
  • 7 Answers
Thermostat is bad...Replace it
Posted on Jan 03, 2014
  • 2 more comments
    Are you losing antifreeze? A bad thermostat left unattended will blow a head gasket. Especa
    Especially if you have aluminum heads and a cast iron block
    How old is the car...How many miles
    its an 2004 with only 140k
Blows cold air turn heat on
Search Results
    07 Tucson heater blowing cold air - Hyundai Forum - Hyundai ...
    www.hyundaiforum.com > ... > Vehicle Line Up > Hyundai Tucson
    Dec 16, 2009 - I have a 2007 Tucson, when you turn on the heater it only blows hot air... Join Date: May 2005 ... a low coolant level will exhibit the first stated symptoms of no heat/low heat at idle and increased heat at cruise due to an air ...
    Denlors Auto Blog » Blog Archive » Car Heater Blows Cold ...
    www.denlorstools.com/autoblog/.../car-heater-blows-cold-auto-service-ti...
    Oct 10, 2009 - When a car heater blows cold air, there are several possibilities that should ...... On my Dodge Neon when I turn on the heat it blows out cold air.
    Heater blows only cool air...even w/ defroster on : Buick ...
    repairpal.com > Problems > Buick > LeSabre
    ... Cadillac, Chevrolet, Chrysler, Dodge, FIAT, Ford, Geo, GMC, Honda, Hummer,Hyundai, Infiniti, Isuzu, Jaguar ... I'll turn up the temp on the dual control to get heat,
Jan 28, 2016 | 2005 Hyundai Tucson
No heat in 2001 dodge stratus,changed Thermostat still blows cold air?
Check the coolant level. If its low you wont get any heat. If its full then I would suspect that the temp. selector on the climate control is faulty. Farley easy to replace. Your local you pull parts yard will have one for $20-$35.
Sep 15, 2014 | 2001 Dodge Stratus
Car over-heats and heats blows cold air
It sounds like the radiator is low on coolant.
You could also have air pockets in the cooling system if the system is not full of liquid.
Jan 15, 2013 | 1998 Lincoln Continental
Engine suddenly over heated, no hot heating in car
most newer car use shut down as a safety feature whenever the temp gets really hot it turns off to save the motor. check your fans if they turn on if they do you might have a bad thermostat.
Sep 19, 2012 | Ford Cars & Trucks
A/c blows warm air when idle, when vehicle accelerated blows cold air. what gives?
when a vehicle stops but is still running it produces a lot of heat,since you still feel some cold air from your ac ,it is working,however maybe not up to par or its just not as much as you would like.The reason it feels cooler when you are driving is the ability to get rid of the heat from the motor because the airflow pulls away the heat from the engine and helps the cooling system.
Jun 06, 2012 | 2006 GMC Envoy Xl
The ac starts out cold and stays that way on hwy driving but starts blowing warm air in stop and go traffic. why?
Either clutch coil is heating up and letting go Or one of the sensors is defective. Or there is a restriction somewhere in the line (open up hood and look for frost on a/c lines.)
Sep 21, 2010 | 2001 Ford Taurus
A/c works heating blows cold air
Is this an electric unit? I guess it is. It appears tha the heating elements are not activating. Check to see if the contactor pulled in on a call for cooling>
Oct 20, 2009 | Carrier YC273D Air Conditioner Window/Wall
Drivers side AC will blow hot air.
the blend motor on the vehicle is probably bad
Aug 20, 2009 | 2003 Chevrolet Silverado 2500HD
No heat
sounds like heater core change it probably your reason.
Jan 10, 2009 | 1992 Cadillac Eldorado
4-Seasons 2004 Chrysler Intrepid Fan Motor Logo
143 people viewed this question
Top 4-Seasons Computers & Internet Experts
Todd Arndt
Todd Arndt
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a 4-Seasons Computer and Internet Expert? Answer questions, earn points and help others
