Question about Frigidaire PLEF398AC Electric Kitchen Range
Ridgidaire model PLCS389ECG, lower burner not heating, upper is working fine
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: The lower burner in the oven of my Frigidaire
The ignitor often goes bad and causes them to fail to light. The igniotr is easy to replace and will fix your problem.
This tip will help you understand this more.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Posted on Jan 27, 2010
Whirlpool gbd307 why will The upper oven not work but the lower oven works
Have you checked the heating element supply voltage with a VOM? And have you checked for a popped/burned fuse to the bake element?
Aug 06, 2014 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool oven WGP30801
Your model suggest a gas unit on gas units only bottom burner operates in bake on electric bottom elements heats broil cycles.
Feb 12, 2014 | Ovens
Oven won't heat, all burners work
I suggest that you remove the upper and lower heating elements to the oven, turn the oven switch to on, then use a good digital voltmeter, and check the plug that the lower heating element was in. If you have good (200 volts or more) then purchase and install new heating elements. Turn the oven switch to Broil setting and check the same way for the top heating element.
May 09, 2011 | Maytag Kitchen Ranges
I recently bought a used Maytag gas range model #crg9700aaw. I am having an issue as the lower gas burner in the oven will not ignite. The broiler turns on and works fine, all the burners work fine as...
I had same problem, same model. Twice in 4 years. Was the lower ignitor gone bad. First time I assume to old age. 2nd time wife overloaded a roaster pan and it overflowed during cooking, and got liquid/**** on the ignitor somehow and killed it.
New one is $43 (http://www.repairclinic.com/Shop-For-Parts?s=t-crg9700-%3d%3d) online. More like $65-75 locally.
Tip: Upper (broiler) and lower ignitors are identical. For a quick test: Swap out the top one to bottom position and see if it works.
It has just today happened AGAIN to me 7 months later. Hence my being online for this.
It's an old horse, and 2 burners up top are acting funny for some time now. Rather than throw more good money into it I think I may trash it and just buy a new stove.
Nov 24, 2010 | Maytag Kitchen Ranges
The lower burner in the oven of my Frigidaire Gallery Gas Range will not come on. The upper burner works fine.
Heatman101
Jan 27, 2010 | Frigidaire Gallery 30" Self-Cleaning...
Lower oven ignitor does not ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven Problems Replacing the Igniter
heatman101
gsgs
Dec 24, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
Frigidaire PLEF398AC Electric Kitchen Range Logo
15 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
