Question about Samsung RSG257AARS - 24 cu. ft. Side by Side Refrigerator
Samsung RSG257AARS, freezer is not cooling things. What can the problem be?
    Sergeant:
  • 236 Answers
Have you checked that the door is closing ok and that the door seals are meeting the door frame all round?
It might be that the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair an engineer will first cut the coolant pipe and drain the existing gas and then recharge, re-pressurise and seal.
Posted on Jan 04, 2014
Samsung refrigerator has 21 E code flashing
Freezer fan error. Most likely the fan in your freezer has stopped working completely
Jul 05, 2016 | Samsung RF260BEAESR 25.5 cu. ft. French...
Freezer temperature keeps climbing thawing out the food.
Check the thermostat, and the cooling fluid.
Tao the thermostat en see if it will start the compressor. When you hear the compressor running and still no cooling, you must have lost the cooling fluid. (used to be freon)
Mar 07, 2015 | Samsung Freezers
Samsung refrigerator wont cool down
JUST ROTATE YOUR THERMOSTAT TO THE MAXIMUM AND WATCH IF STARTS COOLING THEN ADJUST THE THERMOSTAT TO YOUR REQUIRED LEVEL LATER ON. iN CASE IT DOES NOT START COOLING CHECK THE COMPRESSOR WHETHER IT IS WORKING, IN CASE YES THEN THERE IS NO GAS IN IT
Sep 29, 2014 | Samsung RF217ACPN - 20 cu. ft. French Door...
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
Not cooling
your cooling system must be damaged.
Mar 04, 2013 | Samsung RS2530BBP 25 Cu. Ft. Side by Side...
Samsung RS261MDPN not cooling properly
sounds like a defrost issue defrost clock heater or limit could be bad
Jan 18, 2013 | Samsung RS261MDPN - 26 cu. ft. Side by...
I have a samsung cool n cool fridge freezer. The freezer has an electrical smell and certain items are are defrosting??? Temp. Has dropped a degree and is now at17 deg.
Sounds like the defrost heater under the freezer coils has burned
out.Remove back freezer panel and check heater with ohm meter
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Freezers
Intermittent freezing and fridge warm
The ice builds up in the freezer compartment because the defrost cycle is not working. Check the timer , the defrost elements the defrost thermodise.
God Bless.
Jul 07, 2009 | Freezers
Samsung cool n cool freezer & refrigerator does not cool
samsung refrigerator won't cool how do we fix it?
Apr 14, 2009 | Freezers
Samsung RSG257AARS - 24 cu. ft. Side by Side Refrigerator Logo
129 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
