Question about ASUS Essentio Desktop with Intel Core 2 Quad Processor
Need diagram of the back of a emachines Desktop that shows where everything plugs in
    Problem Solver:
  • 3 Answers
What model do you have? most older emachines, gateway and dells are very similar...1) round purple ps2 to keyboard, 2) round green ps2 to mouse, 3) teal oblong serial 1 is older output to modem, 4) blue oblong vga output to monitor, 5) reddish long oblong is parallel port to printer........ all these are usually not used on newer models...others include a white oblong for dvi to monitor, or small rectangular for hdmi to monitor, as well as the traditional usb 2.0 and usb 3.0 for a multitude of input and output usages...... small round female ports are for sound.. pink for mic, green for main speakers, black for rear surround, gray for side surround, orange for center surround, and blue for line in....may also have an esata port (not used much) and a ethernet port for internet connection (looks like a slightly bigger telephone jack port).... might have a spdif (sony phillips digital interface) for digital audio.....hope this may help...
Posted on Jan 03, 2014
How to fix 'no signal' when turn on PC?
it is something about your monitor not connecting well with pc, check graphics card
Mar 25, 2013 | E-Machines eMachines Desktop PC
I need the wiring diagram that shows where on the motherboard to plug the power switch ,power LED, and HDD Led on a T6520 emachine desktop
Most Motherboards are made to only accept certain plugs in that specific spot! If you are trying to add something new like a new Fan or LED, or HHD and you need power you would have to use a 4 prong plug off the power supply, If your power supply does not have any more available plugs, Amazon.com or Newegg.com sells splitters!
Good Luck and Best Wishes!
May 03, 2011 | Computers & Internet
I need the wiring diagram for emachine t5224 desktop pc
Do a Google search for " emachine t5224 manual", and get one. The manual should contain the wiring diagram showing how all components and cables are connected to the motherboard.
Oct 27, 2010 | Computers & Internet
Need a motherboard diagram for an emachines w3503 .
The eMachines W3503 uses an Intel D101GGC motherboard.
eMachines Support isn't going to show you squat.
This is Intel Support, and the download page for the Motherboard Manual, for the above motherboard,
(It's a PDF file. Give it time to download)
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htm
On the above page left-click on -
English Product Guide [PDF}
(In blue)
Need some information about that motherboard, or how to understand the Front Panel header pinouts on the motherboard, state in a Comment.
Oct 03, 2010 | E-Machines eMachines Desktop PC
Getting no image on emachines t6212, the computer was at my mother in-laws and all of the ribbons and power sources were unplugged. i need a diagram of where everything goes.
it's pretty simple. everything has its own plug. and the one for the monitor would most likely be a serial connection, it should have pins at the cord and holes at the computer. the mouse and keyboard have their own connections unless they're USB which wont matter which usb connection ur in. the internet if it's high speed it would look like a large phone cable. and has its own plug. everything else should be alright
Feb 20, 2010 | eMachines T6211 PC Desktop
Emachine t2984 - need to diagram to install power & hard drive
There is 2 main cables you have to worry about to feed power to the system. One looks like a big rectangle block with a mess of wires attached. Make sure he is hooked into the system. Then if its an newer unit you will find a plug that has square look to it with just 4 wires attached and should plug in nearby the processor. (only newer units us this) Also if your dealing with the cant turn it on issue make sure to remove all cards off the board like the NIC, Video Card, and Audio Card. I am unsure as to weather or not your system comes with everything onboard or if its stand alone cards. If you still cant power on theres a bigger issue at hand and that maybe that your motherboard has blown.
Mar 16, 2009 | E-Machines eMachines Desktop PC
EMachine T1440 will no boot on
There is a battery inside the pc, remove it and replace it with a new one. Leaving it unplugged for that long taxes the battery too much. This should help and also plug everything in and reset the power switch on the back.
Aug 19, 2008 | E-Machines eMachines Desktop PC
Floppy error 40
check if the cable is in the correct way stripe toward the power plug
Jul 17, 2008 | E-Machines eMachines Desktop PC
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
ASUS Essentio Desktop with Intel Core 2 Quad Processor  Logo
52 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
